Question about Sony Handycam DCR-TRV330 Digital Camcorder
Camcorder zooms by itself.
TRV330 slowley zooms to wide.I zoom it back to close but as soon as I take my finger off the zoom button or the remote control, it zooms back to wide. Sometimes flipping the zoom button on the camera will stop it from zooming to wide.Several times shutting the camera off then back on stopped the zooming. Sometimes nothing I do will stop it, and it just stops by itself. Sometimes the zoom just won't work, with the camera zoom button or the remote control. Unpluging the remote has no effect. Several times I removed the battery and put it back in and it stopped. Is this a hardware problem in the zoom button contacts or a solid state device problem?What kind of cost for repair should I expect? Will the entire flexible PC board have to be replaced, or can a component be repaired?
  • 3 more comments
  • cdgrant Jul 24, 2008
    I've done a lot of electronic work, including the complete disassembly of my Sony analog 8 camcorder to trace down an audio problem. My only concern is, can i do anything about the problem without replacing the button bar. Is the problem a loose connection on the button bar or connecting plug? Thanks for your quick response.
    I would prefer to repair the problem myself if it can be done without replacing the button board. If I need to replace the button board, where can I get one for the lowest price? I've tried to buy parts from Sony before and could not without being an official Sony Repair Shop.
    Thanks to both responders. Since the problem is intermittent, there most likely will not be a readable voltage on the board's output when I check it. Possibly moving parts and wires around I can find the culprit that is causing the problem. Nonetheless, I will clean all contacts and make sure they are being secured properly. Any suggestions as to which area the problem would most likely be? Thanks.
  • cdgrant Jul 25, 2008
    Sorry but the website you listed only sells accessories like batteries and such. They do not sell parts. If I need a new button board, where can I buy one? Sony just doesn't want to sell to anyone but an authorized Sony Service facility. I had the same problem with the audio board on my analog 8 camcorder, they don't sell them. I needed a connector extension so I could turn the double sided board over while connected to the main flexible circuit board. There was a loose connection on one of the rf coils that cut out the sound when the board was flexed. I couldn't get to the components with it plugged in, so couldn't localize it to a single coil. I thought I would just replace the board but could not find anywhere to buy the board, they just wanted me to send it in and have it repaired by a Sony Authorized Service person.
    Where can I purchase a new button board for the camcorder? Is this a common problem, and if it is, where is it most often shorted out? Thanks for any help you can give.
    President:
  • 2,712 Answers
Unfortunately, the board is not available for sale. This kind of repair is only undertaken at a service center. You could however, try to buy a second hand piece from say Ebay, and try from there..But the only option apart from a second hand purchase would be a service call..
Posted on Jul 25, 2008
  • 3,037 Answers
Sounds like the button is connecting or not springing back like it should. You should be able just to replace the zoom button and just would need to rewire and reconnect it to the camera. The manufacturer should be able to send you a new button. The pieces are so small in cameras, that one piece can easily break off. Let me know of any further questions that you may have on this
Posted on Jul 24, 2008
  • Sony Master
  • 19,396 Answers
More then a problem with the main board, or with zooms gears it looks like a problem with buttons.
If you have already taken apart the camera, grab a multimeter and thest the output from button board. I am sure on one contact you will find some continuos voltage that is what activates the zoom.
Here is Sony spares in UK: Sony Genuine Spares (UK)
    Guru:
  • 1,894 Answers
This is some problem with the panel of buttons is your unit.
this will need some service from the company directly.
  • dewan nafees ahmed Jul 24, 2008
    opening the cam by yourself will make you loose the warranty and also its a very delicate job. and hence needs utmost care and good experience while handling it.
  • dewan nafees ahmed Jul 25, 2008
    it makes me feel that the camera software may be corrupted. because if it is a problem with some particular component then every time you try different things the problem must happen in the same way.
    but your case is not like that.
    the problem differs in each and every case when you try different things.
    and hence this is a software problem i guess.
    also if you are able to clear it in a hard reset its fine else you will have to take some help of service people to reinstall the software.
    thank you
    good luck
    have a great day
What would cause a sony dcr trv120 zoom button not
There is control switch block that has zoom/wide switch along with play, rewind, forward, stop, pause buttons and this switch block flip up and down while ejecting/ load tape in camcorder, this will be replaced as zoom/wide switch got defective and sending continues command of zoom to system control chip.
Let me know if you need part number of switch block control for DCR-TRV120
Jul 27, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
My Elura somehow is zooming in all the time. I can back it out slowly but as soon as I take my finger off - it zooms in again. Please let me know how to fix this. Thanks
the zoom in rocker is stuck, its a physical problem, you need to try cleaning it with surgical alcohol and an ear bud. or take it to a camera repair shop.
May 06, 2010 | Canon Elura 70 Mini DV Digital Camcorder
JVC Enverio GZ-MG155 30gb camcorder
Try removing the battery and see if it changes back to the default settings.
Aug 04, 2008 | JVC Everio GZ-MG130 Camcorder
Cant see full picture w/ Vizio 32in HDTV
You would look for a format button on your remote.
Dish Network: bottom left the asterisk "*" button
DirecTV: top left, second from the top labelled "format"
Cable remote: look for format, zoom, or aspect ratio
Pressing this button should scroll you through the options.
Apr 16, 2008 | Vizio L32 32 in. LCD HDTV
Zoom
change the camera operation unit
Nov 16, 2007 | JVC 580136 Camcorder
Canon Elura 60 zooms by itself
Listen, I know it's a couple of years after this post but, try this: Remove cassette, push to close, close camera as if to use it, hold firmly in left hand, open hand slap it with your right hand once or twice, (I'm not joking) it worked the two times I had this problem. Problems with the zoom? Almost same process, push firmly on zoom button (to un-zoom) try doing this as your tapping it. These are last ditch efforts on an aging camera, it really has been a good one. I've put this poor thing through years of abuse, and it's held up pretty well. Good luck, Jeff S.
Oct 16, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Zoom problem
Ive seen this three times and everytime its been something differant. Fist was the rocker switch was jammed. easy fix as dirt was in there. Second was a small serface maounted capacitor in the zoom interface circuit. An third never found the problem as we thought it was a limit switch in the lens itself but the customer never paid for a new lens assy so we didnt order it. Good luck
Jun 21, 2006 | Canon XM1 Mini DV Digital Camcorder
Sony Handycam DCR-TRV330 Digital Camcorder Logo
183 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
