Question about HP Pavillion ZV6000 Notebook
Screen dim to black
I was using my hp pavillion zv6000 laptop and the screen went black. I thought it just prematurely went into hibranation so I fiddled with the switch that is puched when you close the monitor and turns the screen off.
This brought the regular screen back but in about 5 min it died again and it is now a very very dark dim screen where I can barely make out anything.
Thanks in advance.
  • tinman00 Jan 07, 2009
    i Have a hp omnibook3000ctx th screen is black but it come on I can barely make out anything.I hit f1 f2 fn nothing.
I had this problem, and it was the inverter - a $20 part. I got it off of ebay and replaced it myself. Or you could just plug in an external monitor and forget about it....
Posted on Oct 11, 2008
    Genius:
  • 2,028 Answers
This will be a problem with either the screen inverter or screen backlight. You will need to take it to a shop for diagnosis, in order to find out which one it is. If it turns out to be the backlight, then the entire screen will have to be replaced. They are considered a sealed unit, and the backlight can't be changed out.
Posted on Jul 24, 2008
I just got a 1 gb ram memory from you for my pavillion zv6000 laptop. I opened the back to install it and there is a ram in there already. I thought I was just adding memory. help
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
section 5.6 gives memory specs, earlier in the manual it only refers to one memory slot. You have to pull the existing one.
I always tell my customers what the max memory you can install, and what will have to be removed. Apparently someone else didn't.
You might want to download that pdf. It's the full maintenance manual on your machine.
Jan 08, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Reboot to factory settings hp pavillion zv6000
You can use f11 key to boot your system to recovery manager and performed system recovery there to restore your system back to factory default.
Aug 05, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
HP Pavillion ZV6000 - Charging Problems
hi
It seems that your laptop is not charging so in that case you must take your laptop to your vendor.For more support you can visit---------http://robs-tech.blogspot.com/2009/06/free-solution-regarding-computer.html
Jun 22, 2009 | HP Pavillion ZV6000 Notebook
HP Pavilion dv2000 would not start up, black screen
try to re install first the software or program then observe if the same problem,, check the lcd inverter...
Jun 07, 2009 | HP Pavillion ZV6000 Notebook
Hp pavillion zx 5000 screen black
GO ON LINE AND TYPE THE MFG NAME, MAKE, MODEL, SCREEN WENT BLACK.
ENTER
ROD
May 12, 2009 | HP Pavilion dv6000z Notebook
HP Pavillion zv6000/ USB Problem
Go to the HP support for this PC at http://welcome.hp.com/country/us/en/support.html and search for your laptop.  Here you can download the USB drivers or any updated drivers that you may need.  If still no dice, then uninstall the USB driver, restart and try loading it again from the download.
Oct 29, 2008 | HP Pavillion ZV6000 Notebook
Hp pavillion zv6000 white screen on startup
bad video maby bad ram bad screen one of them or bad power chips on mobo worse case
Jan 29, 2008 | HP Pavillion ZV6000 Notebook
Screen Blackout
u must be having problem in output display driver,,,try replacing it
Oct 31, 2007 | HP Pavillion ZV6000 Notebook
Blank screen
motherboard problem or
ram problem
Oct 26, 2007 | HP Pavillion ZV6000 Notebook
HP Pavillion ZV6000 Notebook Logo
161 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
