1 Use MULTI-CONTROL to select Clock.
2 Push MULTI-CONTROL left or right to
select the segment of the clock display you
wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the clock display:
Hour—Minute
As you select segments of the clock display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
put a clock right.
Turn the cds upside down in the unit. not sure on the buttons but if you get it to play you will understand, I used to have a 6 disk trunk cd player and the disks always had to be upside down
With power OFF, press and hold the FUNC (or CLK) button until the date and time are displayed. Use the up/down/left/right control to set numbers and change positions....when happy with date and time turn unit ON..should be good to go.
Sorry, but I don't think you can use the rca's for an aux-in. I bought a deh-10 new and there is nothing in the owners manual that even mentions useing the rca's for an aux-in.
Used it long enough to opperate it in the dark and nothing in the setup menues for changing those rca's from outs to ins.
Turn the radio off; press and hold the multi-control button in (the big round one). Language should pop up, turn the round button right until you get to clock. Use the multi control to change the numbers.
On most pioneers you press source to turn the radio off (while the car is still in the run or ACC positin). Then press and hold FUNC to enter the menu. Then use the directional joystick to make the changes.
Try this, which works for most Pioneer car radios, they say.
Turn key to ignition on or accessories position, turn radio off. A time should be displayed, and maybe it is incorrect.
Press the Function key and hold it for 3 seconds and the hour will flash. Use either the up/down or the left/right button to change the time. When finished, I think you push the Function key again.
From the Pioneer Electronics website;
How do I set the clock on my single CD player?
For most Pioneer single CD players, you can set the clock using the following steps:
1.Press and hold the SOURCE button until the unit shuts off.
2.Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button.
3.Press the left or right arrow to select the segment of time you wish to adjust.
4.Press the up or down arrows to increase or decrease the numbers in the blinking segment.
5.Once the clock is set correctly, press the SOURCE button to exit.
have the same problem, have you found out how yet?
