Question about GE Kitchen Ranges
My stove is a Ge Profile from 1998- when I turn on the oven F3 flashes- and shuts off-
  • 5,911 Answers
Every fault code I have found for GE model ranges says this fault code is an oven sensor error. The oven sensor is a small probe that sticks out from the oven wall (usually along the back or side somewhere). This probe varies in resistance as the oven heats and sends a signal to the control board. If the probe is defective, or if you have a broken wire, you will get this fault code. The following link explains how to troubleshoot and/or replace an oven probe:
http://www.fixya.com/support/r393313-checking_replacing_oven_probe
I hope this is a simple fix for you. The repair is simple if you follow the instructions. If you require assistance locating any replacement parts, please post back with your complete model number. I hope this helps you.
Posted on Jul 24, 2008
GE Wall Oven JTP 10GP F3 code when I turn it on it goes straigt to F3
on our maytag a f3 code means shorted or open temperature sensor. do not know if that code is the same as a ge, but you can google your oven model codes and find out what the problem is.
Jun 21, 2010 | GE Profile JTP18 Electric Single Oven
What does F3 mean on a GE self cleaning ove. When
Your oven tempertaure senser is bad (RTD)
Jun 25, 2009 | Cooktops
GE Profile elec range JSP40 Locked door flashing can't use oven
Replace the oven temperature sensor to solve the F3 problem.
You may need to replace the oven lock micro switch to solve the locking problem.
Change the sensor first. Then try the oven.
Mar 04, 2009 | GE JSP46 Electric Kitchen Range
F3 code flashing
Replace your oven temperature sensor.
F-3 bad sensor.
Feb 02, 2009 | GE Profile JTP18 Electric Single Oven
I'm getting a F3 Code and beepingfrom my gas stove/oven.
F3 means open ven temperature circuit you will likely need to replace the oven sensor.
Dec 31, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Oven Model JKP13G0V1BB
f3 is a bad oven sensor, two screws will remove it in the upper left or right hand side of inner cavity.thin metal shaft protuding maybe 3inches or so.
Mar 23, 2008 | GE Profile JTP18 Electric Single Oven
F3 code
It's your oven temperature sensor. It's a thin metal stick that juts into the oven. It is located on the upper right back wall of the oven cavity. Flip your breaker, slide out the oven. You install it from the back, very simple, two screws, i think. I'm a beginner at DIY and had no problem fixing it.
Feb 23, 2007 | GE Profile JK915 Electric Single Oven
Kitchen Ranges Logo
258 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
