Question about Xerox WorkCentre M20i All-In-One Laser Printer
Constant Paper Jam1
Every copy we try is getting a paper jam1.  Pull it out and its accordian'd and not fused.
What would I need to do to get it working?  Want to save it from the recycle stack :).
  • JWellner Jul 24, 2008
    Found fusers for about $129.  Really reasonable.  Are there any take aparts around for this thing?
    Thanks!
    Oh heck... that's EASY!  Thank you very much!!!!
  • 81 Answers
It sounds as though you need a new fuser assembly. Not too expensive and worth having repaired. You should contact a technician in your area.
Posted on Jul 24, 2008
  • diane szczesniak Jul 24, 2008
    Not really, but if you open the right side cover, you will see 4 silver screws. Take those out and then disconnect the small plug. Be gentle and you should be fine. Oh yeah, let the machine cool down before you take the fuser out!
Why it has error:paper jam1 ?
Paper jam 1 error means paper has been picked up and has not reached fuser paper sensor in a fixed time .
check for any hinderance under the toner cartrdige
or bad pikup assly
Jul 07, 2015 | Samsung Office Equipment & Supplies
Error Code : 0x5a
The detail code 5a in Fujitsu fi-5900 scanner is displayed due to frequent paper jam error. To resolve this issue, you need to clean the two lenses of JAM1 sensor and check it's performance.
Also, to resolve paper jam error, you need to check the condition of pick,separator,brake rollers, feed and pinch rollers. Replace the rollers if required.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Aug 01, 2014 | Fujitsu fi-5900C Pass-Through Scanner
My printer instantly gives paper jam1 and I have to open and close the front door that covers the toner. Please anyone knows how to fix this problem or what is couse it... as it was working perfect .....
Probably it is not your printer, that causes the problem but your paper. Laserprinters are very sensitive for paper, paper humidity etc. Try to print with paper from a new box (or sealed) of paper.
Jul 01, 2011 | Samsung ML-2851ND Laser Printer
Samsung ml-2550 paper jam1 problem
Carefully check for any paper stuck in the system.
Does the error go away on reboot? or is it constant?
Does the error occur every time you print or just sometimes?
May 06, 2011 | Samsung ML-2550 Laser Printer
Jam1 indicat with redlight on
Hi. Jam1 error comes when the pick-up roller (the one that pull the paper in to the fax) is durty and can`t pull the paper.If you give the model of the fax it will be easier to help you cleaning the roller.
Oct 20, 2010 | Office Equipment & Supplies
It say error JAM 1 what does that mean
Look inside printer to see af any paper is in there if so remove.Pull out paper tray and clean pickup roller (roller that picks up paper from tray)if the roller has film on it it will cause jam1 error
Mar 22, 2010 | Dell 1600n All-In-One Laser Printer
Brother 2820 constant paper jams
Most likely the fuser is worn out, and needs replacement
Jun 02, 2009 | Brother IntelliFax-2820 Laser Fax
Error message paper jam1 on my samsung scx4016/xaa laser print
check paper guides also check if small pieces of paper are stock inside the printer from previous jams also check the sensors
May 26, 2009 | Office Equipment & Supplies
Samsung scx4016/xaa paper jam message 1
open backside of printer and look foe any misplaced parts inside...
May 26, 2009 | Samsung SCX-4016 Laser Printer
Panasonic DP 4530
E4- 02 Paper Jam 1. Paper Jam in Fuser Unit.
2. Paper Exit Sensor 1 or 2 is disconnected.
3. Paper Exit Sensor 1 or 2 is defective.
4. DRV PCB connector is disconnected.
5. DRV PCB is defective.
6. SPC PCB connector is disconnected.
7. SPC PCB is defective.
Oct 19, 2008 | Panasonic Workio DP-4530 Copier
Xerox WorkCentre M20i All-In-One Laser Printer Logo
140 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
