Question about Samsung (SP0411N) 40 GB Hard Drive
Enquiry i have a samsung SP0411N hard drive i wanna know if it can actually be repaired
    Problem Solver:
  • 19 Answers
Yes, the HDD can be repaired.
Posted on Jul 24, 2008
I have a new Samsung SP0411N hard drive , I want to replace the hard drive but the bios say Pri Master Hard disk S.M.A.R.T . Command failed . Any help Please .
check your cables, if its ok,
check the jumper, if theres any,
try boot with only one hdd.
else, try consult to the manufacture for firmware update. there might a compatibility problem.
Oct 16, 2013 | Samsung (SP0411N) 40 GB Hard Drive
Hard disk is not detecting samsung sp0411n internal hard disk is not detecting
Make sure the power cable and IDE cable is plugged in properly then boot your computer up again. If it does not work, test it on another computer to see if the hard drive works at all.
Sep 18, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Model sp0411n s/n s01jj30y201985 warranty details
This is a old hard drive, I doubt it will be still under warranty.
Oct 20, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Samsung40 gb harddisk unable to format (SP0411N). But i can read old data. I cant delete anything. cannot delete partition also
Try formatting / partitioning the drive with windows xp setup / installation cd. If you are trying to format or delete partition in windows and its your c: drive you will not be able to do that.
Jul 30, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Remove the bad sector from samsung sp0411n
Although A format could help it sounds more like you have some bad sectors on the harddrive.
Right click on the drive, select properties, then select the tools menu and initiate a disk check. it will give you an option screen before it proceeds, select the option to scan for a recover bad sectors/clusters. This will write off and mark the bad sectors so they will not be used again. If the problem comes back again soon then your palette media is failing and you should replace the drive.
Good luck and let us know how you make out,
Chris
Jun 03, 2009 | Samsung (SP0411N) 40 GB Hard Drive
My sp0411n my hard disk of capacity 40gb it is showing 5gb space my know reason why it is showing 5 gb space
hi first off what OS (operating system) is installed. Did you install that OS?
If the answer is yes ,did you format and partition your hdd or did you format and create separate partitions and left atleast 30 gb unpartition
Feb 27, 2009 | Samsung (SP0411N) 40 GB Hard Drive
WE WANT THE WARRANTY DETAILS
1 to 3 year warrenty they will give you
in 1 year warrenty if your drive not responding totaly than they transfer to dealer & they will transfer to production house for replace ment
1 more thing if they had say you for life time warrenty than its also equal to 3 year warrenty.
so take care of it.
THNX
May 17, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Samsung SP0411N HDD, error message while booting shows "Pri Slave Drive - ATAPI Incompatible" "Press F1 to resume" thakurbs@hotmail.com
Hi guies ,
                   you haven't specify which kind of error message displayed on screen ,please  do same
Oct 19, 2007 | Samsung (SP0411N) 40 GB Hard Drive
My HDD has seen in BIOS but it can't read data
Maybe the pins on the inside are disconnected happened to my dads harddrive
Aug 20, 2007 | Samsung (SP0411N) 40 GB Hard Drive
CMOS auto detection of samsung SP0411N HDD stops and hangs
Hi download this program its seagates diagnostic tool, put in floppy disk and run program to make a boot disk, restart pc, and let it boot off the floppy disk and it will test the drive for you... http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=DiscWizard&vgnextoid=d9fd4a3cdde5c010VgnVCM100000dd04090aRCRD All the best john
Feb 16, 2007 | Samsung (SP0411N) 40 GB Hard Drive
Samsung (SP0411N) 40 GB Hard Drive Logo
98 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
