Question about AT&T Sony Ericsson W580i Cell Phone - White
"Latch" Question What do you mean by the "latch"? On the w580i, you push the SIM card into its slot and it locked in place. The battery is then placed in the phone against the SIM slot. There is no latch that I can see. Can you explain? Thanks!
  • 4 Answers
A latch is where you put a strap, it's weird i know, just push the sim card in...simple :)
Posted on Aug 07, 2008
My lg phone says to add smart chip
The smartchip is the SIM. Without knowing which model you are working with it's hard to say for certain what the problem may be. On my older W580i, you have to slide the SIM all the way into the slot - until it actually clicks, locks into place and doesn't pop back out when you release it. The battery will not properly hold it in place.
For several other models I've seen people indicate that the SIM needs to be shimmed slightly - with the edge of a folded piece of paper, for example - to properly hold it in position against the contacts.
Nov 08, 2017 | LG Cell Phones
How can I fix a blank 8 gb sd card for my Samsung galaxy note 3?
8 GB SD card is compatible with Samsung note 3.
You need to remove rare cover by just pulling it out.
Then, remove the battery. Push your blank SD card in slot provided above SIM card slot. Push until it locks into place.
Insert the Battery and place cover back to its position.
7ba50913-19c0-4eb0-94d4-57794ff3a880.jpg 3728ef8b-58f4-4fa6-a4d8-970fff340a44.jpg f0bfba0d-c4e5-425a-8573-3691e0158507.jpg
Jul 18, 2014 | Cell Phones
How to install sim card in acer aspire?
Turn off your laptop. Open the battery door on the back, remove the batteries. That is where the sim card slot is located. Push the sim card into the slot with gold contacts facing up. You'll feel it when it locks into place. Replace your battery and cover. Then turn on your laptop. Thats it.
Jul 11, 2014 | Cell Phones
How do i put my bobbin basket back in help
do you mean the bobbin and bobbin case? Load the bobbin then lift latch on case to hold it in position. place it over hook centre post and engage finger in locating slot release latch, push in and you should hear it lock
send machine info for detailed instructions
Feb 18, 2014 | Sewing Machines
Nokia c7 sim card removal i don't now how ??
Insert the SIM card and battery
Important: Do not use a micro-SIM or a micro-SIM with an adapter in this device. This device does not support use of micro-SIM cards, and use of incompatible SIM cards may damage the card or the device, and may corrupt data stored on the card.
Follow the instructions carefully, to avoid damaging the back cover.
Safe removal. Always switch the device off and disconnect the charger before removing the battery.
1 Unlock the back cover release latch, and lift the back cover
2 If the battery is inserted, lift the battery out.
3 Insert a SIM card. Use the diagram printed on the device to correctly align the card.
4 Line up the contacts of the battery and the battery compartment, and insert the battery.
5 To replace the back cover, direct the top locking catches toward their slots, and press down until the cover locks into place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Nokia C7 (8 GB) Smartphone
Sasiwadan@yahooCANT REMOVE MY SIM CARD FROM THE SIM SLOT BENEATH THE BATTERY
It should be a "push push" action. If you gently push it in, the latch should release.
Hope that helps.
Feb 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
I just removed the SD card to view some pictures and now when I put it back in it will not latch and stay down. I have tried two other cards as well and none will latch and stay down. They do not seem to...
The first thing that comes to mind is to make sure you have it in the right direction. You should have the metal connectors of the CD card facing AWAY from the batteries. Even if the card fits the other direction, it is a must to have the connectors the right way.
Some CD cards are affected in use by whether or not they are locked or unlocked. Even if you don't remember locking the card, those things can be slid pretty easily. Check to see if perhaps your card got moved to the "locked" position. (The lock is a miniscule little slider to the left of the label on most SD cards. It should be at the TOP to be unlocked, unless your brand has printed directions that differ on the card itself.)
Also, you can always try turning the camera upside down with the battery door open. Don't hit it, but if there was a little piece of dirt, it would hopefully fall out.
The SD cards need a little quick push to lock into place, and need a quick push to unlock as well.
If you check on all of these, and it still isn't locking into place, it is possible that there is a bent pin on the SD card. I haven't experienced a camera that had a problem with the SD slot yet in 8 yrs of owning digitals, but I have had bent card pins...
I hope one of those helps you.
Oct 01, 2010 | Canon PowerShot A1100 IS Digital Camera
My camera has placed a Protected card ! on my camera without my approval
No! I do not think your camera has placed a Protected card ! on my camera without my approval. Pull out your memory card and look for a very small "latch" at one of its sides. Push it the other way and try to access it again. This "latch" is the "lock/protection."
Sep 29, 2009 | Fuji Finepix Z20fd Digital Camera
AT&T Sony Ericsson W580i Cell Phone - White Logo
26 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
