Search for:
sewing machine timing
lots of videos and web sites that discuss how to set it
-I know you already did what you can. It's frustrated.
How about try this:
When you want to sew thick material, make sure increase the foot tension.
-If the needle is broken, make sure replace with the same length needle. If the new needle is little long or short it will not pick the bobbin's thread. This is call off timing.
-If needle is same size then yes. the timing is off.
-I do not have any video to show you how to adjust, but you can watch in you tube. Just type " Adjust sewing machine timing"
It'll pop couple video there from others expert. so watch then you will have some idea how and where to adjust.
Good luck
Mai
SOURCE: needle will not pick up bobbin threat
I had the exact same problem. The timing is off. You can actually fix this yourself all you need is an allen wrench. If you look at the rod the needle is inserted into and follow it up to about 2 inches below the top of the machine there should be a clamp. use the allan wrench to loosen the clamp and adjust the needle height. I used this website as a guide to getting the timing correct. http://www.sewusa.com/Sewing_Machine_Repair/Repair_Pictures/timing1.gif
now if only I could figure out why my thread keeps getting jammed under the bobbin!
Try flipping the bobbin spool so the thread comes off in the other direction.
Forcing means that the needle has been jammed against the sewing plate ant the needle is now out of timing with the bobbin pickup.
SOURCE: Cannot get the bobbin thread to come up with the top thread
1. Make sure the needle is up in the machine all the way.
2. Make sure the flat side of the needle is facing the rear of the machine
3. Only turn the handwheel on the side of the machine towards you, never away from you.
4.Double check your threading of the top of the machine.
5. Also make sure your using the proper needle, your machine takes the most common needle on the market but some look like it and are shorter or longer and wont work properly. Also make sure your not buying needles for a singer serger.
SOURCE: My needle does not pick up the bobbin thread. I
Make sure that you have the needle's flat side facing the rear of the machine, or else it will never grab the thread. Also, make sure you hold the top thread in your left hand until it grabs the thread and you pull the bobbin thread up
