Question about Panasonic Microwave Ovens
I have a Panasonic microwave model nn-sa616wx sn 58100747 it keeps triping the breaker after it operates for awhile we have taken a amp reading and it draws 17.2 amp.This is a new microwave.
  • willy silb Jul 25, 2008
    thanks for trying
  • 93 Answers
Safety first, unplug your microwave from socket outlet.Needs to troubleshoots series of components using eliminating method to know which component(s) that causes breaker to trip off. It is obvious that a componet(s) "shorted out".Remove your fuse and replace it with resetable breaker tested.
Remove leads of the transformer output(secondary side). plug power cord run the microwave.If does not trip off the cct breaker change your transformer. do the same to capacitor lead, one after the other until you discover which component that shorted and cause your cct breaker to trip off.
Posted on Jul 24, 2008
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
I need a manual for the panasonic NN-CT562MBPQ
The manual can be downloaded here:
Put in the model number with no spaces: NNCT552W and take the one marked "Operating Instructions".
Feb 26, 2013 | Panasonic Nn-Ct562mbpq Combination...
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
Model: NN-SD277W.     serial number: 6A88040672 A.
There is a dead short in the microwave oven that can be any number of things, yes you will need a pro to fix this and I suggest an estimate first.
Mar 12, 2012 | Panasonic Microwave Ovens
My circut breaker keeps triping. i need to know how many amps it uses so i can get the right breaker
Most domestic microwave ovens draw arount 1kWatt on microwave and the same again for convection.
If it is a European country (230Volts) maximum power will be 10 Amps, 20 Amps on 110Volts.
If the breaker is an RCD type, you have an earth line fault!
Dec 14, 2010 | Goldstar MV-1515 Microwave Oven
My model is nn-s253wf, micowave stopped working, no power, checked circuit breaker, is ok ?, unplugged, then plugged back in, still no power ?
Inside the external case and usually to the right left ( from Front) in some models There is a 30 amp fuse ( This may vatry on oven output amperage) Replace that and you should be back in cook mode.
Removing the case you should remember to disconnect from the power plug.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic NN-S252WF Microwave Oven
My NN-T695 Panasonic microwave oven starts up for two seconds then cuts out before doing any warming?
I'm having the same problem with the same model microwave. It has taken hard use for a long time, but now it will (sometimes) start and then stop after a second or two. I think it's a loose connection, because a couple of times I got it to work by rapping on the back or side.
Mar 02, 2010 | Panasonic NN-T695SF Microwave Oven
Microwave Ovens Logo
678 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
