Question about HP Officejet 5610 All-In-One InkJet Printer
Hp officejet g85 all in one
Cant recieve fax error comes up remove transparency paper which i do not have in my printer am using 20lb , 92 every day copy paper
  • janet20d Aug 10, 2008
    do not know how to set up to receive faxs
  • 28 Answers
- try to unplug the power cord of the printer
- do the semi full reset
- press and hold the # and 6 keys
- and while holding the 2 buttons replug the power cord of the printer.
- do not release the two buttons yet
- wait for the printer to starts up
- if it turn off, release the two buttons
- then it will appear the smei-NVM reset
note: this can only be done once.
Posted on Aug 31, 2008
Can't print on transparency film
In order to print on transparency film from a HP8600 all you have to do is load the paper rough side down with the white border going into the tray toward the back of the printer so that you can not see it when you look into the paper tray. The HP 8600 will auto-adjust for the film, that is why you do not have the option to select transparency like you did in the HP 8500
Dec 22, 2012 | HP Officejet Pro 8600 e-All-in-One -...
The following is my exact problem...can it be repaired? Hard to tell if piece is broken. "My faxes are not printing. The error message says there is a paper mismatch and tells me to remove the transparency...
Somewhere, your printer has a sensor (probably a light and a mirror and a detector), to try to distinguish between transparency media and opaque media (such as a sheet of paper).
So, that sensor either has a piece of transparency media stuck inside it, or it is otherwise misdiagnosing what media is between the light-emitter and the light-detector, and thus is claiming that there is transparency media loaded into the paper-tray.
It sounds like you need to take the printer to a qualified technician.
Dec 03, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Paper Jam - HP G85 Ink Jet Printer
You open the door from the back of the printer (turn the knobs) and the paper can be removed from the back. After removing paper jam, replace the door. It is a long door as wide and the printer, but about 2 1/2" wide.
Feb 28, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Paper Mismatch
Dig through the menus on the printer and make sure the paper type for the tray in question is set to plain. Sounds like someone set it to transperency and forgot to change it back.
Aug 29, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
You guys need a new fax modem. Very easy to install. We have them for $25.
Aug 07, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Paper mismatch
Sounds like your spot sensor is broken. It will give you this error if not working properly. It is attached to the right side of the cartridge carriage and emits a small blue light when paper is fed in to the machine. It looks at the paper and tells the machine the paper is there or in this case not there.
Jul 10, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Recieving fax no printout, all other printing processes ok
When you say all other printing processes are ok, I am assuming you can make copies and print from the computer. If so...then are the blank faxes coming from several different fax machines or are they coming from one particular fax machine. If one particular fax machine, then the problem is probably on their end. I need to go backwards a second....when you receive a fax does the machine spit out a blank page or no paper is fed at just receives the fax? Is the machine programmed to just receive faxes to memory to be printed out later? It doesn't make sense for it to print or copy but not to print a fax. If problem persist try a different fax modem.
May 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP G85 auto-answer
yeppers...same thing happens to mine. So, I simply set it to receive faxes manually now.
Jan 18, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Won't allow undisclosed numbers to fax such as IRS
Jan 15, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
214 people viewed this question
Ben Johnson
