Hi...i run a childcare center where we use our turntable all the time.
We have a philco model number EL-177.
Where can I buy a new needle?
thanks
beverly
What you need to do is look at the cartridge it fits in. It should have a make and model number on it. Put them into a Google search and the cartridge and Stylus should come up.
You are talking about the adapter that have to be inserted to center shaft of the player, before playing records of 45RPM I assumes. It can't be purchased from any spare parts selling shops. Contact the nearest authorised service center for Philco.
Check lpgear.com for Philco stylus replacement. You may need to find the "Contact Us" tab and request information for your particular model, but if they can't help you, then contact Philco (division of Ford Motor Co.)
hi, before you buy a new motor first check the selector switch if it work in proper...some times the connection even though you range it into desired position inside of the selector not in connection ..( solution: move the selector switch ON and OFF 5 0r 10 times or more as long as you can.. or try to take some Multi tester to know if there a continuity of the selector swich..u
turntableneedles.com has about 450 belt sizes in stock. your unit is too new to have this listing yet as the belt should not have failed already so when you call be ready with the length of the old belt. Don't worry that it is stretched, a new size will be calculated that is about 3-5% shorter.
about 3% of the time the 'brains' get scrambled, try unplugging it from the wall for a few minutes, sometimes this will 'fix' it.
if so, a power surge from your power company might have got it confused, if the problem continues try a surge protector power strip.
Your gonna need a model # man. If http://www.remotes.com dosent have one, Look in the owners manual for an addy and contact the company there. Good Luck
