Question about Eureka 2971AV EZ Kleen Bagless Upright Vacuum
4870MZ Eureka The Boss Smartvac - Red
Tube on side of the vaccum that goes to the top is clogged and i cannot remove it to clean it out. the clog is stuck and cant get it to move.
How to I remove it to undo the clog?
  • 77 Answers
Must disassemble the airways to access some clogs.
Jim
Posted on Jul 28, 2008
My shark navigator freestyle is clogged.
There's also a screen in the dust cup(where everything goes) mine was clogged there, just scraped the dust off it. And it stopped venting out the side.
Mar 15, 2014 | Shark SV1100 Navigator Freestyle Cordless...
Eureka Smart Vac The Boss no suction from either setting. I have taken it apart trying to see if it was clogged but it isn't. Checked the hose it is not sliced.
Remove the bag cover and feel for suction above the motor. If their is suction there then check the bag compartment is sealed. You can drop a coin down the hose to check for blockages all the way to where the bag attaches.
Aug 16, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have no suction on my Eureka Smartvac. I cleaned the inside, it had been attached incorrectly so the inside compartment was full of lint, changed the bag but still no suction. My husband unhooked the...
Tear apart all hoses and make sure no clogging, also take apart to expose motor and make sure their is no dust on motor, this will cause symptoms you are describing, another thing check Impeller fan and make sure the fan is running and not blocked if fan is not working then will need to replace Impeller.
Eureka burning smell
Hi, it's Cindy from Crucial Vacuum.
Since you have replaced your Eureka 4870MZ 9200 Proheat 2x vacuum's belt, the issue may either be caused by your roller or the position of your belt. It sounds like as soon as your vacuum is lowered, the belt is either slipping or wear on the end caps is causing your roller to stop. This will cause the burning smell since your motor is now straining against the abrupt stop. Try taking off your roller and checking the conditions of the end cap or try to reinstall your belt. I have included an instructional video: http://youtu.be/rji0fl9hytY
You can purchase direct your replacement brushroll from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/eureka-smart-vac-roller.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 20, 2013 | Eureka The Boss SmartVac Upright Vacuum...
Lost suction but no cloggs in line
see the solution; God bless you
How to determine a clog in your hose
Take your central vacuum hose and connect it directly to the dirt canister. After turning on the vacuum if the hose has normal suction here then the clog exists in your tubing.
Click here for help with tubing clogs. But, if you experience reduced suction at the canister then your hose is clogged. See Solutions below.
check.gifPlug hose in reverse into the inlet located on your unit and turn on the system. This should aspirate the clog out.
check.gifOr, remove the hose from the inlet and push a garden hose through hose to push out the clog. Most importantly, the garden hose must be turned off and there should be absolutely no water entering your vacuum hose.
check.gifOr, remove the hose from inlet and drop in a heavy object such as a screwdriver to push out clog.
Jul 23, 2012 | Broan-NuTone VX475 Bagged Central System...
My beater bar wont turn once in a while the motor will start
check the ends of the bar and clean if necessary , and replace the belt
Jul 08, 2011 | Eureka Boss? SmartVac 4870MZ Bagged...
I have a Eureka bagless, The Boss, there is a clog behind the top dirt catcher. I have cleaned every other tube, filter, clogs, etc.. I can't get my hand up into the main housing. Thank you so...
Try using a straightened wire coat-hanger. You should be able to bend a small hook at the end of the wire, and then bend it to get to the clog. If you can get the clog to move a little, but can't get it all the way out, try putting the vacuum back together and turning it on again -- sometimes just loosening up a clog will be enough to let the vacuum **** it through.
May 26, 2011 | Vacuums
The hand held hose is clogged at the very bottom how do I unclog it
Disconnect the hose and run a stiff wire or dowel in and out of it.
Mar 27, 2010 | Eureka 4870SZX BOSS SMARTVAC PET LOVER...
Loud noise/Sounds clogged
You could have a clogged air filter and vacuum is not getting air to motor. You could have hair and string buildup on ends of roller brush. You can put a vaccum hose over a broom handle to clean it out. Also, check the little elbow of the hose at the bottom f vacuum where it bends.
Aug 28, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Eureka 2971AV EZ Kleen Bagless Upright Vacuum Logo
228 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
