Question about Car Audio & Video
A electronic subwoofer crossover
Im not sure if you can help me with this or even if you will get this but i have a crossover i want to hook up to my amp because the amp dont have a low pass switch... my cross over i believe is active it has 4 speaker wires coming out of one side and out puts for the amp rca's on the other... plus a power,ground,remote wire... how do i hook it up is the question? so if any of this helps with you helping my question would be great thanks.... you can reply to my email
  • 25 Answers
Connect speaker wiring for car to speaker wire side. plug the rca's into the amp ground the ground wire. run a live from the battery to the power on the crossover and run the remote wire to the blue (iso connector) wire coming from the back of the radio
Posted on Feb 19, 2009
Tryin to hook up a mtx electronic crossover rt-01a. i dont know how to hook it up
Your basic crossover is going to have a power (+) and ground (-). Your power wire goes to the battery, and your ground goes to the frame. You will need to hook up your RCA or speaker wires to the input side. Then hook the other two RCA connections to your amp.
Apr 13, 2011 | MTX Car Audio & Video
Hi ive got like music playing through my 12 inch sub aswell as bass im pretty sure subs are just their for bass. ive changed RCA cables i dont know how many times new amp sub head unit and power n ground...
Hello..... I can help you with this problem. You need a crossover to remove all of the high and mid frequencies from the subwoofer. If you run the sub at "full range" (all frequencies), you will destroy the voice coil. If your amplifier has a crossover on it, put it in the "low pass" or "LP" setting. If your amplifier does not have a built in crossover, you will need to add one. A crossover can cost as little as $29 for an electronic one. This will fix your problem. If you have any other questions, just comment back and I will be glad to help you!
20 year car audio/video installer
Bay manager
Mar 27, 2011 | Car Audio & Video
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
Need help.. I have two 12 inch dual voice coil kicker comp vrs.. they are 4 ohm do i wire them to get a final ohm load between 1.5 to 4ohms in a dual enclosed box...Im hooking them up to a jl 500...
To do this they MUST be wired in parallel, IE: Plus to Plus, Negative to Negative. 2 4 OHMS in parallel is about 2 OHMS in series it would be 8 OHMS... series is positive to negative. Are you using a crossover network?
Mar 05, 2010 | Kicker CVR12 Car Subwoofer
I need installation manual
its not a subwoofer it is a midrange speaker. all you do is connect your outputs from the radio to the crossover then connect both the tweeter and midrange to the outputs on the crossover. it is called a component set.
Oct 01, 2009 | Quantum Audio QP500C Car Subwoofer
Where is the crossover located in the mackie srs 1500and does the crossover have a fuse.
The Mackie SWA1501 has an active electronic crossover on its main circuit board.
Jul 15, 2009 | Mackie SWA1501 Subwoofer
The tweeters in my yamaha NS-515F have blown. Any ideas where i can purchase suitable replacements? is a popular source for loudspeaker components.
Also, are you sure the tweeter's blown, and not a crossover component? carries many electronic components that could be used in crossovers.
Dec 02, 2008 | Yamaha NS-515F Speaker
Car stereo crossovers
you should be able to remove the passive in-line crossover, but since it is blocking everything below 3500 hz, there is no need. leaving the passive crossover in place will also help protect the tweeters if something fails in your setup as any amped frequency below 3500 can seriously damage them.
Nov 11, 2007 | Infinity Kappa 10.7t 1'' M.M.D. Dome...
Go to the following website where you can get the service manual for $17.00, unbelieveable, don't you think? The service manual should help you sort out your hookup problems. Good luck.
Jun 10, 2006 | JVC RX-818V Receiver
Car Audio & Video Logo
150 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
