Question about Denon DRA-455 Receiver
DRA-625RA Turned on no output, LCD only one tiny segment on, looks like in standby mode.5A mains good
Had this Denon Reciever since arnd 1986? Never had any issues. Today noticed what sounded like clipping (I use it with a Nikko EQ Pre out/Main in) and Polk Audio Monitor 5's. Just sounded like it lost horse power. Turned it off, and when I turned it back on, nothing. I used the remote. When I engaged the power button on the remote again , the FM strength indicators lit momentarily. No LCD display, except tiny segment,very faint. I checked the remote, battery's, good. Tried manually and just like above. But the indicator(s) #24 OM, show mode, like in stand by. 5A main fuse good. No smell. Took the hi voltage plate off, no burning etc. Couldn't locate secondary fuse. D505/506 etc rec not fried on outside...soo any help would be much appreciated, especially with money being tight. I used to work for a Denon warranty authorized service center in the 80's called Astro Service Center in Burlingame, CA for the Good Guy's etc. I did lots of research back then. Thanks Tony
  • startouchb1 Jul 24, 2008
    I did check wiring harnesses and any physical connectivity issues. At this time I don't have any tech data. I was thinking it might be one of the power output IC's. And if it does have a blown secondary fuse hidden away, would I still get some data on the LCD (telling me which input is selected? Thanks, T.
SOURCE: avr 1804 denon 7.1 reciver
Did you check the Audio-Video slider button in the middle of the remote? It needs to be on Audio, else the remote sends video channel number signals when you press the numbers.
Posted on Jan 09, 2008
  • 54 Answers
SOURCE: Denon AVR-1602 Overheated!
Hold on......there are 4 small resistors in the power supply that open up ( no longer work ). This is a VERY COMMON PROBLEM for 01-02-03 model Denons. They are "flameproof" resistors, so when they burn open, there is no trace of a problem, they look normal. This pic is from a 1601 which is almost identical. The resistors are missing from the picture, but you can see where it is marked R 141, R142, R143, R 148.
If your shop measures across these resistors and they are more than 10 ohms, then they are blown, and this is your problem. These should each be replaced with a 1 ohm 1/2 watt Metal Film Flameproof resistor. You must also remember that the little 1602 is NOT a professional unit, designed to be cranked for hours on end. It is a home theatre receiver.
If this solves your problem, be happy and dont beat your receiver to death. .....THIS BEING SAID.....the other reason that these blow is because one or more channels are blown and drawing too much current from the power supply. IF that is the case, be prepared for a big bill. DO NOT try and fix this yourself, as the entire receiver must be taken apart , right down to the bare chassis to get this board out. Leave it for a professional. Have them check the resistors first, it only takes about 10 minutes to get the cover off, check the resistors and put the cover back on........hope this helps... Rob
Posted on Mar 13, 2008
SOURCE: denon 1508- no sound but smoke.
perhaps u might consider going to a(n) (unauthorised) repair centre. just check with folks around u or maybe audio forums within your area. authorised agent doesn't always mean the best. i suspect they may have used reconditioned components.
Posted on Sep 01, 2008
  • 85 Answers
SOURCE: Denon DRA-555 Memory won't hold set FM stations when powering up
Most probably the memory capacitor / battery inside soldered to pcb
Posted on Jan 09, 2009
AJIN G
  • 6694 Answers
SOURCE: I called a Denon service
hi,
Blinking of power indicator means the amplifier is in protection mode.First of all remove all the speaker connections from the amplifier. After that power the amplifier and check the protect show or not . if not, then any of the speaker is damaged. If then also it shows protect you have to check the amplifiers hardware.
AV receivers shows protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong.
Normally AV receivers show this when any of the output amplifier have some problem. There are seven amplifiers in this AV receiver. May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
You have to check the amplifier.
For that you need digital multimeter,soledring iron screwdrivers etc
Open the amplifier , then power it on. connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). then connect the positive terminal to all the output transistors emitter pin one by one . the voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
after replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. put the bulb in a holder. now you have to wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim . if so check the display, is there is protect mode is on or not . if not and come back to normal operation ,then remove the power , remove the bulb insert fuse and check
connect the power and check.
If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components.
ok
Posted on May 19, 2011
Denon dra 25 no power
John,
If you have a multi meter then unpug from mains supply.With meter
on "ohms" range check the following:-
Fuse F501 (and F502 if mult-voltage model)
yellow to white on mains transformer this should show some resistance.If you have a mult-voltage model check
brown to gray and orange to white. Both should show some resistance, if not your mains transformer has an open circuit primary winding.....
Mar 03, 2014 | Audio Players & Recorders
I have done some research about my denon arv-1601 reciever, narrowed it down to a ressistor problem, it turns on for 4 seconds and turns off and goes into standby mode. Any Suggestions?
Usually it is bad power supply problem or bad channel problem. Look for any burned parts, it helps you locate the problem. Burnt resistors in one channel- you need to replace output transistors (better to replace all transistors in that channel) and bunch other surrounding parts. If you do not see any burned parts, check all voltages coming from power supply +15 -15 +5 etc then check dc at every channel output (not at speaker terminals but at control pins on the amp/main pcb), should be +-10mV
Sep 05, 2011 | Denon AVR-1601 Receiver
My denon DRA-295 does not remember stations I set to memory when completely turned off. If on standby all goes well. A month after the problem mentioned above the tuner started to modulate reception and...
My better guess is a CMOS chip is either bad or there is a cold solder connection in the vicinity. If the power supply is bad, the receiver would not power up.
Nov 23, 2010 | Denon DRA-295 2 Channels Receiver
The power supply has burnt out on my denon dra-455 reciver.
It really depends what and how much burn't up? The only way to find out it to take the top cover off and look inside. A lot of parts in the power supply section can only be replaced by excat parts due to safety reasons. And are you certain it's the power supply that's gone up, and not the POWER AMP section? It could be just one part that started smoking. If any semi-conductor has burnt up, you might not be able to read the code number, in which case you will need the service manual.
SO GET LOOKING INSIDE!
Jul 01, 2010 | Denon DRA-455 Receiver
I'm convinced the fuse is blown in Denon Receiver, I'm having trouble locating it...where is it?
There is a main fuse located either close to where the AC cord enters the unit or under a PC board attached to the transformer. In any case, it is unlikely that the fuse is the real problem. Is there a standby light at all or nothing at all? If there is a standby light, the fuse is fine. If the unit won't stay on or turn on, the problem could be a bad 5V supply or shorted outputs.
Please update this with any additional symptoms and I'll provide additional details.
Thanks,
Dan
Mar 16, 2010 | Denon DRA-375RD Receiver
Denon dra-95vr receiver has no sound out. All
Two things to check. First, the 95VR can be deceiving because it has a "variable loudness" control that some may mistake for volume. The actual volume is controlled by the big up and down arrows on the upper right side. If the volume is turned up, you should see the volume bar graph display show up. If none of the inputs are giving you volume, and the volume is turned up, then try running the output from the processor loop output in the back to another amplifier. The processor out is jumpered to the processor in for normal operation. Missing jumpers could cause a problem also. If there is sound coming to the processor out, then you have a problem with the power amplifiers. Best to refer that to a technician.
Dec 29, 2009 | Denon Audio Players & Recorders
I have a Denon DRA-397 Receiver. It was stuck with the "Panel Lock" but I followed the instructions here to hold the "B" and "Mode" buttons while powering on. It unlocked the panel. Now the Reciever is...
Check for a reset of the receiver. If no mention in manual you might want to check with the manufacturer for a code . If nada then the electronics are fubar and you are SOL.
Aug 31, 2017 | Denon DRA-397
Denon dra 1025ra seems to be stuck in standby mode. How do I release standby to power up
Unplug receiver from AC outlet, and plug back in. The power reset should clear up the problem.
May 18, 2008 | Denon Audio Players & Recorders
Denon DRA 685
Could it be that the speakers load is too much for the amp to handle? What are the ohm ratings? It should handle a low load but I am just wondering? How effcient are they?
Nov 29, 2007 | Denon DRA-685 Receiver
Denon DRA-455 Receiver Logo
278 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
