Question about Whirlpool LER5636P Electric Dryer
Squeaking Our dryer is now making a squeaking sound on every revolution. The belt around the drum seems firm and I doubt it's that. How can I fix this? Thanks, Mike
  • Jeanne Dodge Jul 27, 2008
    My dryer says it is Whirlpool model # LEN2000JQI Imperial AccuDry, which I cannot find on the list. I bought it used and have no instructions on how to get to the parts to lubricate. Can you help with a picture or opening instructions?
  • 5,911 Answers
The squeaking is usually attributed to any (or all) of the following:
The drum support rollers
The rear drum seal
The front drum ring bearing
The front drum seal and bearing assembly
The Idler Pulley
Now before you throw yours hands in the air in a panic, these parts sound more technical than they are. All the bearings and seals for the drum are either felt or plastic, the drum rollers support the drum at the rear bulkhead, and the idler pulley is what the drive belt rides on. Searspartsdirect.com offers excellent illustrations to show you where these parts are located. Just type in your complete model number and there will be a part listing with part numbers on the next page. If the model number you posted this under is correct the parts can be found under the following headings:
"Bulkhead Parts"
Drum Support Rollers (item 44) Part #349241T (pkg. of two)
Rear Drum Seal (item 66) Part #279857
Front Drum Ring Bearing (item 62) Part #279441
"Cabinet Parts"
Drum Seal and Bearing Assy. (item 38) Part #3406129
Idler Pulley (item 53) Part #691366
I list all these parts as a convenience in case you need to order any of them, and to help illustrate where these parts are located. You may not need ANY of them.
The drum support rollers require lubrication at the point where the roller meets the shaft with a light turbine oil. This should be done periodically to keep them rolling smooth. DO NOT get any oil on the rubber rollers or it may cause the drum to slip. You should also remove any build of lint before lubricating.
The drum seals can become brittle with age and start making noise as the drum rotates. This is particularly true with the rear drum seal. It will become discolored with age and turn brown in many cases. Inspect the front and rear seals of the drum for excessive wear. If parts of the seal begin to protrude into the interior part of the drum, this is a good sign that the seal is bad. The seals cannot be lubricated and will require replacement.
The idler pulley is a small plastic wheel on a shaft that the drive belt rides on. Lubricating the idler pulley wheel in the same manner as the drum roller supports is also required from time to time. DO NOT get any oil on the drive belt.
I know this seems like a lot, but a simple matter of cleaning and lubricating may be all that you need. If you require further assistance, please let me know. I hope this helps you.
Posted on Jul 24, 2008
GE dryer DCVH515EFOWW thumping noise after heats up. Recently replaced front drum bearing and slides which fixed squeaking. Now having rhythmic thumping (no squeal or squeak).
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Aug 18, 2014 | Dryers
How to repair squeaking sound when in operation
it most commonly has to do with the inner wheels needing to be replaced. either the tub wheels or belt wheel.
May 19, 2014 | Maytag Bravos MEDB200VQ 29" Electric Dryer...
GE dryer Mod # DWXR463EG1WW is squealing. Does anyone know what is wrong with it and how I can fix it?
Sounds like a rear bearing . remove the 2 screws from the top when you open the door . this way you can take the top off . When you take the top off remove the screws on the inner left and right on the front panel. disconnect the belt from the pulley and motor and pull the drum out . then you will see the rear bearing . cheap fix but can be a pain. good luck
Feb 16, 2013 | Dryers
I have an electric frontload dryer. If I turn it on with nothing in it, it sounds like there is a shoe tumbling around. If I open the door and spin the drum by hand, each revolution the drum makes, there...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 22, 2010 | GE Dryers
Our dryer has a terrible squeak. We replaced the
The terrible squeak is probably the idler pulley shaft spalling in the idle pulley mount. When the idler pulley siezes to to pulley shaft it spins in the mount and makes a horrible racket.
It can be the motor bearings also but I doubt it at this time. With the belt off you can spin the motor and listen for any odd sound. If you hear nothing then the problem is definately the idler pulley assy.
It is normal for the drum to float in place. When there is a problem with the drum or drum felts, you usually hear a cyclic scrape or grinding sound that is concurrent with each rotation of the drum.
Thanks for using FixYa.
Kelly
Mar 05, 2010 | Frigidaire GLGT1031C Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Inglis Citation dryer still squeaks
just an idea.....try to match the squeak to the revolutions of the drum or the guide pulley.
if the squeak is fast it is probably a guide pulley or a roller that the drum rides on. if the squeak is farther apart then the drum is wearing in one spot and rubbing on something. check for wear spots around the drum area.
hope this helps.........jay
Mar 21, 2009 | Dryers
Dryer drum doesn't turn; makes a loud squeak sound
The problem is most likely your drum belt. Most run all the way around the outside of the drum, across a tensioner pulley, and around the motor.
This could be easy, or it could be a nightmare. Disassembly of the outer cabinet can be tricky. Some drums ride on pullies, while others slide on drum felts.
Your local appliance parts store can give you some guidance, and probably a few cards of qualified service guys. If you're mechanically inclined, and have a history of being able to take machines apart, AND reassemble without extra parts laying around, then give it a shoy. Otherwise, pay a pro, and save your Saturday.
Jun 25, 2008 | Dryers
Kenmore 80 series dryer.
true story.I brought my lawnmower to a friend of mine,i said to him Tony my lawnmore is making a terrable noise, he said to me worry when its making no noise...its possable a worn tension pully it would make a rattle like sound,Solution replace pully wheel!.Top of the morning to you Eire
Nov 15, 2007 | Kenmore 63942 Dryer
Whirlpool LER5636P Electric Dryer Logo
233 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
