Question about Epson Office Equipment & Supplies
Epson Printer Problem
I have an Epson Stylus 860 ink jet printer. When I attempted to print a greeting card, the paper feed stopped before it reached the print heads. The red light on the Load/Eject button came on blinking. Normally when that happens I press the Load/Eject button, the sheet feeds through and clears the paper feed path. When I pressed the Load/Eject button in this instance, the paper feed did not move. Instead, both lights on the Cleaning button came on blinking. The Light on the load/Eject button continued to blink.
I have removed power from the printer, Started and restarted the computer several times. I have removed and reinstalled the printer. The three lights always come on blinking when I power up the printer. I cannot clear it. I cannot move the print cartridge carrier to replace the print cartridges..
Any suggestions to cope with the problem will be appreciated.
Sincerely
Carl Clark.
  • jdccvc Jul 24, 2008
    There is no paper in the printer of any size. I removed all paper and inspected the paper feed path when the problem occurred.
  • 3,037 Answers
Your waste ink pad has become full and the counter must be reset along with the pad replaced. New pads can be bought from the manufacturer.
You can use the SSC service utility to reset the protection counter. You can download the utility from here http://inkjetprinterhelp.us/epsonSSC.html
You can also use the control paler to reset the counter. Timing is the key to success when you reset the counter using the control panel so keep that in mind.
To reset the protection counter using the control panel (front panel)
Step 1.Turn the power on while holdint the following buttons doen. Paper feed, cleaning button. (thr paper out light will flash for 3 seconds)
Step 2.While the paper out light is still flashing press the cleaning button for 10 seconds. The following leds will flash in sequence Ink out lights black and color, Paper out light. Once the printer starts to initilize the counter should be reset.
This will reset the protection counter. Again timing is the key to get the the above sequence to work. Also it is a good idea to replace or clean the absorber pads For info on the basic process try this link http://inkjetprinterhelp.us/wip.html
Posted on Jul 24, 2008
  • Epson Master
  • 1,879 Answers
Greetings,
Remove any paper loaded and check for any obstructions.
Powercycle the printer 2-3 times while disconnected from the computer.
If the lights are still flashing, the unit needs servicing.
I understand the fix is more costly than the printer ( check this link http://www.epson.com/loyalty ).
Keep us posted and thank you for using our service.
FixYa - Technical Support, Instructions & Repair Service
    Genius:
  • 3,422 Answers
HI,
Press the Epson Printer Problem - fonts.gif load/ejectbutton. The printer ejects the jammed paper and then resumes printing.If the error is not cleared, open the printer cover and remove thejammed paper. Then reload paper in the sheet feeder and press the fonts.gif load/eject button. The printer resumes printing.
    Sergeant:
    Champion:
  • 347 Answers
Hello Carl Clark,
is the greeting card still inside the printer? because if it is, all of this problem might just be a jam inside the printer.
    Brigadier General:
  • 6,966 Answers
Initially, pls try and do a manual reset.
  1. Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
  2. Release all buttons.
  3. In 2-3 seconds time press and hold CLEANING button, until all leds will blink.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 24, 2008
    Alternately, you can try:
    1. Power off the machine for at least 5 minutes and remove connection to the computer
    2. push and hold down the "ink" button and the "paper" button and power on the printer.
    3. Soon as the "paper" light flashes, quickly release both the buttons and
      then immediately press and hold down the "ink" button only for at least
      10 seconds.
    It may have to be done a couple of time.
    Additionally, you may to try a third party multiple reset for Epson printers, SSC service utility. Download, install and run.
  • Epson Master
  • 19,396 Answers
Looks like a problem ith the tractors not catching paper properly, slide a sheet of coarse thick paper inside the printer.
  • Ginko
    Ginko Jul 24, 2008
    The printer has a mechanic problem it must be probably taken apart to fix it.
  • Ginko
    Ginko Jul 24, 2008
    Also turn printer upside down and check that there is no foreign object stuck inside.
    Try playing with the tractors at the back of the printer.
My EPSON Stylus Photo 1400 Ink Jet Printer is printing blank photos. The ink levels are fine, it's feeding photo paper fine, it's making the same noise as it does when it prints but the photos are...
Your problems states that photos are being blank when trying to print it.
Please try these tips.
  • Make sure your printer is selected in the Print window or in the Macintosh Page Setup and Print windows.
  • The print head nozzles may need cleaning.
  • Make sure your printer software settings are set for the paper size you're using.
Plus,i also wanted to know if you can print ordinary documents or print a test page.
Hope this helps.
Thanks,
FixerDelta
Sep 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
EPSON 1280 SILVER INK JET PRINTER, Stopped printing on glossy
Problem with paper feeder. Replace paper feeder or replace just pick up rubber at paper feeder mechanics. You can add thickness of rubber by adding black double tape (flexible) (about 1mm).
Jun 15, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Epson stylus color 880 printer has a paper jam. It printed color in area with no paper, so to get ink out, I fed in a paper towel. Now the towel is stuck and torn remnants cannot be reached from above. ...
OK this takes a bit of technique and bravery. You need a stiff piece of card such as the backing from an A4 notepad or similar. Turn the printer off and insert the card into the paper feed. You will need to align it with the pick-up roller and push it through quite hard to overcome the spring pressure. It will push out the bits of towel so open the cover and fish them out. Feed the card all the way through and out of the cover. Always try to remove paper jams in the direction of paper feed.
Hope this helps, please take a moment to rate this solution. Thanks.
Apr 02, 2009 | Epson Stylus 880 InkJet Color Printer
Problem printing - Epson stylus photo 895
1 bring out the catridge of the printer to clean and make sure the ink flow during the cleaning.
2 insert and reset the catridge.
Oct 11, 2017 | Epson Stylus Photo 890 InkJet Printer
Black ink mark
try this......run a card with heavy matte paper using 'regular settings'.....see if the extra black is gone then
Oct 04, 2008 | Epson Printer
Epson printer that can print at art glossy paper
Epson's ink uses a dift technology so far better result you need to check what brand of glossy or photo paper you can use. You can purchase an epson photo or glossy paper for best results.
Your printer would work best using the list below:
Paper Types
  • Supports a variety of Epson plain and photo papers. Supports plain, bond, air mail, Epson Premium Bright White, Glossy Photo Paper, Premium Glossy Photo Paper, Premium Semigloss Paper, Premium Luster Paper, ColorLife paper, Matte Paper Heavyweight, Double-sided Matte, Inkjet Transparencies, Self-adhesive Sheets, Photo Quality Ink Jet Paper, Greeting Cards, High Quality Banner paper; labels; envelopes, Iron-on Transfers and Photo Stickers; Printable CD-R/DVD-R; Panoramic 8.3" x 23.4" Photo Paper
If you may have other questions pls feel free to ask.
Just rate me Fixya if your issue has been resolved.
Cheers.
Jun 17, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus COLOR 1520
There could be something wrong with the connections going to the ink jet cartridge in the printer.
Someone should take a look at it.
Jun 14, 2008 | Epson Stylus 1520 InkJet Color Printer
Epson Stylus Ink Jet Printer
1. Turn printer off
2. Press the left 2 buttons down and continue holding them down while turning the power button on. (all 3 are now pressed down)
3. In 3 or 4 seconds, the paper feed (jam) LED light begins to flash. (middle button)
4. Within 3 seconds as the paper feed button LED still flashes, release all 3 buttons together and immediately press down the ink cleaning button (left) and continue to hold down for about 10 - 20 seconds. As soon as the cleaning docking button LED flash, release it. That's it! You are now reset and ready to go.
NOTE: This is a strict timimg procedure and must be done fairly precisely in order for it to work. It may require several attempts for it to work for you. But...it does work! Happy printing!
Oct 12, 2007 | Epson Stylus Color 880i InkJet Printer
131 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
