HOW TO HOOK UP MY LABTOP TO THE NET WITHOOUT USING A ETHERNET CORD
  • BARKLY54
    BARKLY54 Jul 24, 2008
    how doi find the security key or passphase for my rjsa07 wareless connection on my labtop?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey BARKLY54,
If you didn't have the opportunity to write down your wireless security passkey/phrase previously, you should still be able to obtain it by accessing your wireless router's main menu. This is normally done by visiting one of the following websites from a computer that is already connected to the wireless network, or is hard-wired into the router itself:
192.168.0.1
or
192.168.1.1
Please keep in mind that the default address you'll need to visit may vary depending on your router model, so you may wish to refer to your owner's manual documentation for more information.
Once you've gotten to this page, you should be prompted to provide a user name and password to access the router's main menu. This default user name and password are generally provided in the owner's manual as well (or in documentation given to you by your ISP if you had that company set up your network), unless you have made any changes to these in the past.
After you’ve signed in, you should be able to find your wireless network passkey/phrase under an option named something similar to “Wireless Settings” or “Wireless Security.”
It is important to remember however, that any changes made while in the router’s main menu (intentional or accidental) can have a direct impact on every device currently connected to the wireless network. If you’re not sure how to proceed, I would strongly suggest contacting your ISP or local technical support agent for more information.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jul 24, 2008
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
Can not connect to internet with TL-WR340G
try to unplug and replug ethernet cord. if the ethernet port has no blinking lights try to change ethernet cord.
May 16, 2012 | D-Link DI 514 Wireless Router (DI-514)
IM TRY TO SET UP MY X BOX ON LINE ITS ASKING FOR A WPA2 KEY FOR NET WORK WHAT IS THIS
This is the security code to access your network wirelessly. Use the same code you use to hook up any computers in your house. You can also just get an ethernet cord and hook directly up to the router.
Aug 08, 2010 | Microsoft Xbox 360 Console
I hooked an ethernet cord to my belkin router so i could connect it to my xbox 360 and it dosent work so i connected the cord to my laptop to see if it was the cord. The cord works but it wouldnt connect...
if it says limited connectivity then the port on the router for ethernet is not working
* u need to do hard reset on the router using a paper clip * press the reset till u get a feel of a click * then hold it down for 1 min * then while holding unplug the powercable and plug it back * then release the reset then try with cable connected to computer then if not working * check with different cable if not working try with different computer *still doesnt work then u need to replace the router as the ports on the router not working
Mar 05, 2010 | Gateway Belkin F5D7230-4 802.11g Wireless...
How can i get my internet to work on my labtop with no ethernet ?
You can purchase a usb Ethernet adapter that plugs into the side of your laptop. You could buy a wireless card that could fit into your computers card slot.
If you mean that you don't have Ethernet in your home you could go wireless and use whatever free access you might find. Check out an electronics store for improvised attachments. Many types are available.
Feb 19, 2010 | Compaq Computers & Internet
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Can i get a connection to xbox live with a verison wireless USB MODEM?
yes you can all you need to do is hook up your usb modem to a computer or laptop and hook a ethernet cord to your computer to ur 360 note- hooking a usb modem in a 360 will not work. ive had mine hooked up 24/7 to halo3 it works wonderful may glitch once in a blue moon but its better than hughes net never ever ever ever get hughes net get verison!!!!
Aug 18, 2008 | Video Game Consoles & Games
Westell 6100 ethernet
the prob may b with the ethernet adapter on the computer or the ethernet port on the modem or the ethernet cable.....
to check ethernetadaptor  ping 127.0.0.1
to check the ethernet port on the modem...if u plugin the cable u should have a light lid up on the modem ..
to check the ethernet cable  try with an alt cable which is proved to be working
Jul 26, 2008 | Westell Wirespeed LiteLine 6100...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
