Question about Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-TRV37 Error code C:32:20
Ejects tape repeatedly
  • 1 more comment
  • Anonymous Sep 27, 2008
    tape keep ejecting and code c:32:20 comes up
  • ftboymando Oct 21, 2008
    My Sony Handycam CCD-TRV37 8mm has a tape stuck 1/2 way in with an error code of C:32:20
  • huwman Feb 16, 2009
    CCD-trv57 and the tape is stuck, tape won't move either way. Code 32:20 says "T reel side tape slacking when unloading." How do you fix?
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Posted on Oct 21, 2008
  • Frank Hinterberger
    Frank Hinterberger Dec 27, 2013
    Mine tries to open with this solution, but no go and the error code returns. Any other possible solutions?
    It's also a CCD-TRV65. Get both C:31:20 and C:32:20. Once the door actually raised up, but then went back down again. Never opened.
Tape keep ejecting and code c:32:20 comes up
Posted on Nov 08, 2008
Ftboymando thanks for solution! I was have problem with stuck tape but in Sony DCR-VX2100E. Fortunately, your solution was also good for this model :)
Posted on Nov 05, 2011
Yes! Even my mean old CCD-TR713E works again!!
Thanks for the tip
Posted on Sep 19, 2014
Sony camcorder CCD-TRV37 manuals
The manual for your Sony Handycam CCD-TRV37 can be found on the Sony eSupport website here:
http://esupport.sony.com/perl/model-documents.pl?mdl=CCDTRV37
May 28, 2011 | Sony Handycam CCD-TRV37 Camcorder
Sony 8 MM HaNDYCAM PROBLEM
Yes It Is Possible.
1. Cable options you can use S-video or RCA.
2. VHS payer that has a recording option. Make sure that it supports the Sony Handycam 8mm.
3. The procedure on how to transfer the 8mm to VHS is the same as how you view your video on the TV.
4. S-video or RCA should be connected on the Handycam and the other end is on the TV.
5. You can follow the instruction on page 27 (Sony Handycam CCD-TRV37)
6. You can also follow page 52 (Sony Handycam CCD-TRV37 )
Go to this Link for the user manual and the full instraction on how to connect the cables.
http://www.derrybryson.com/manuals/Sony/Analog%20-%208mm%20&%20Hi8%20Camcorders/CCD-TRV57.pdf
Apr 03, 2010 | Sony Handycam CCD-TRV37 Camcorder
Erasing the tape on a sony handycam vision please
Well the cheapest way is to go into record mode, cap the lens with the black lens cap and record a 'black' picture on the tape. This will erase all the pictures on the tape and leave you with a 'black' screen on the whole tape.
Oct 05, 2009 | Sony Handycam CCD-TRV37 Camcorder
Will this unit play 8 mm cassette tapes that are formatted "mp"?
You want to purchase the Handycam CCD-TRV37? If so that is 8mm. If your referring to another camera give me the model and I will let you know. Though I would consider switching over to mini-dv. The quality is alot better and is the standard now so there are many models available.
Thank you,
Lee
Jun 24, 2009 | Sony Handycam CCD-TRV37 Camcorder
Error code C:32:20
My best solution, is to pull all power sources form the camera for 24 hours. If this does not work, then take the small screws surrounding the Tape housing, in order to try and get the tape out. Best of luck dude ;)
Feb 05, 2008 | Sony Handycam CCD-TRV37 Camcorder
Continually ejects
The clip that catches may be out of alignment, best to have a repair shop take a quick look.
Jan 12, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-TRV37 Code C:31:10
it is whats called moisture condensation. this happens when the camera goes from a cold to a hot environment very quickly, and vice versa. Simply leave the camera standing with the tape door open for about an hour, and then try again. If this does not fix it, then try cleaning the video heads, and make sure the camera is not in a humid environment, as this will also cause this to happen.
Dec 28, 2007 | Sony Handycam CCD-TRV37 Camcorder
Sony handycam DCR-HC18E tape stuck won't come out
Unfortunately this is a problem only fixed with an expert repair man. Camcorders are just to complex to try getting a tape out.
Dec 23, 2007 | Sony Handycam CCD-TRV37 Camcorder
Camcorder problem
there is an eror code displayed on the upper corner of tle lcd. that code will tell what is the problem with the unit.pls post the code for more info. anyway this needs the intervention of somebody who has some experience with camcorder repairs.
Jun 07, 2007 | Sony Handycam CCD-TRV37 Camcorder
PLEASE HELP!! Sony Handycam CCD-TRV37
The problem is usually caused by no drum rotation. Have it serviced.
Sep 14, 2005 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-TRV37 Camcorder Logo
3,495 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
