Need to disable a key on my keyboard
I recently upgraded my computer & it came with a new keyboard. This keyboard has a drop-down menu key on the right side of the right Window key & every time I try to hit the right shift key I hit it also & it takes me out of what i'm typing & to the drop down menu; it's driving my crazy!!! The new PC is a Dell Vostro 200 & the keyboard model # is L100. I would really appreciate any help you could give. Thanks :)
  • christymmi Jul 25, 2008
    When I right click, my only options are open & create shortcut & when I open it, there are no key options. I think I might just pop the ****** out if I can figure out how! thanks anyway :)
  • 781 Answers
Check your keyboard in
Start/settings/control panel/keyboard right click open check what options available you may be able to stop key working
Posted on Jul 24, 2008
Cat sat on keyboard. not a limerick... keyboard slow to respond with arrows and typing. Also light on top LHS under '1'... what is that ?
Hold down the shift button for a few seconds to disable sticky keys. This is a windows feature to help people with disabilities and is activated and disabled by holding the shift button down for a few seconds. You can also disable it under start menu/programs/accessories/accessibility
Jan 22, 2015 | HP Compaq nx9030 Notebook
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
Numeric keypad on keyboard stops working after signing onto desktop computer
Sounds like a short key is being activated when you are pressing series of buttons disable short keys on your PC options menu or hold down the shift key then disable the short/hot keys menu
Feb 22, 2013 | HP Pavilion Computers & Internet
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
Remove toolbars from dropdown menu
Clear the Dropdown Address Bar For security and privacy's sake, you might want to clear the drop-down address bar in your Firefox browser. You can do so in just a few steps. Note that these entries will not be retrievable after they're deleted.
Launch Firefox browser and click your cursor inside the address bar. Begin to type in the address that you wish to delete, but do not press "Enter" or click "Go." You will see the drop-down list auto-populate. Using the up or down keys on your keyboard, scroll down to the item you wish to remove from the listing. Press the "Delete" key on your keyboard to remove it permanently. Your browser will now be free of specific items that you wish to remove. Remove Unwanted Toolbars Permanently Web toolbars are add-on programs that enhance functionality of your browser. Usually they improve your online searches, offer quick access buttons to favorite websites and some provide pop-up blockers. However, there are spyware programs that only pose as toolbars. Yet other toolbars, although not harmful, install themselves without your consent. You can easily remove these unwanted toolbars permanently from your PC.
Go to the "Start" menu and click "Control Panel." Click "Uninstall a program" under the Programs area. Scroll through the list of currently installed programs, select the toolbar that you want to remove and click "Uninstall." Follow the step-by-step prompts to uninstall the toolbar. Restart your computer when prompted at the end of the removal. b> Firefox Launch Mozilla Firefox, click the "Tools" drop-down menu, select "Add-ons" and click "Extensions." Click the toolbar you want to remove in the new window. Click the "Uninstall" button. Restart the browser.
Clear the Drop Down Menu in Mozilla Firefox b> Firefox's "autocomplete" feature helps speed up your Web browsing experience. Whenever you type in the browser's location bar, a drop-down menu appears. This menu may contain a mixture of previously visited websites and entries from your bookmarks collection. Although this feature makes it easier to revisit old sites, you may want to clear this drop-down menu when it becomes too large. Clearing the menu can reduce its and prevent others from viewing your browsing history if you share the computer.
Launch Firefox and click "Tools" to display a drop-down menu. Click the "Clear Recent History" option to view the "Clear Recent History" pop-up window. Click "Details." A list of options appears. Remove the check marks from all options, and place a check mark next to "Browsing & Download History." Click "Clear Now." b> Clear Bookmarks Click the "Tools" button again, and then click "Options" to display the "Options" window. Click "Privacy" and find the "Location Bar" section near the bottom of the window. Click the drop-down box in that section and click "Nothing." Click "OK."
Jan 29, 2013 | Mozilla Firefox
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
How to deactivate shift key sound on windows keyboard
Right click on the speaker icon in the bottom taskbar select playback devices then sounds tab scroll through all device sounds select it then from the drop down list select none
this will vary depending on your operating system
or
Click "Start."
Click "Control Panel."
Click the "Sound" icon.
Click the "Sounds" tab.
Click on the listing for the sound that currently plays when an action is performed on your keyboard.
This will select it. Click the drop down menu on screen and select "None." Click "Apply" to disable the keyboard sound in
hope this helps
Oct 10, 2012 | Computers & Internet
I got a new key board it was working yesterday when i kept switching my pc on and off but today it wont work what cud i try
Hi
Please check whether your keyboard is properly plugged in to your computer. If it is plugged in properly then try and change the slot of the keyboard(if its a USB port keyboard). If this doesn't help then try to check the BIOS settings for keyboard settings.
To enter BIOS settings press DEL key continuosly or F8(Function key 8) continuosly until the BIOS menu appears. Under the menu select the option of Hardware->Keyboard-> check whether it is enabled or disabled. If it is disabled then enable it.
Try using this keyboard with another Computer, if it doesn't work with other Computer as well then you can get it replaced for a new one.
Daniel Scott
Jun 12, 2010 | Computers & Internet
Some letters like ( a;e,i,o,p ,y) ar nt working on the keybo
for people who activate them accidentally. If you decide you need to disable a key, just follow these easy steps:
1. From the Tools menu, select Customize…
2. In the
Customize dialog box, click Keyboard
3. The Customize Keyboard dialog box will open
4. In the scroll box beneath the Categories label, select All Commands
5. In the Commands scroll box, find the command name for the key or keystroke (you’ll have to do some searching to find the specific key you wish to disable, but here’s a freebie: to disable the Insert key, select overtype)
6. Highlight the key or key sequence in the box below the Current keys label
7. In the drop down box beside the label Save changes in: select Normal to apply the change to all documents created in Word. To disable the key only to the current document, select the document name from the list
8. Click Remove and then Close
9. Click Close on the Customize dialog box
Dec 18, 2008 | Gateway 2520915 Keyboard
Computers & Internet Logo
4,754 people viewed this question
David Payne
David Payne
