Question about HP PSC 2410 All-In-One InkJet Printer
Hp psc 2410 photosmart all-in-one;
Just stuck in the photo cartridge & it gives me an error message....remove & check cardtidge in right stall. The color cart. should be ok.
  • socalwoman Jul 26, 2008
    I have the same error that jnwebb reported: remove & check cardtidge in right stall. I did and now it says print cartridge in right stall not supported. I don't know what that means but when I take the cartridges out and put them back in I get the first error, and then the second over and over again.
Download free
Posted on Aug 16, 2008
I do not want to use color cartridge in my hp psc 2410 printer. But without installing this cartridge, the printer is not working
Inkjet printer require both cartridges to be installed and have ink to go online. There is no way to bypass this function. If the printer does not detect the cart when it tries to perform a head clean cycle you get the error you have displayed on the screen. All inkjet printers are like this not just HP.
Apr 11, 2013 | HP PSC 2410 All-In-One InkJet Printer
Print cartridge in right stall not supported for hp 2410
Print cartridge is a knock off. Cartridges have printed circuits in them that the printer can recognize as being the original replacement. This is to keep people from using other products in their printer, which I think is foul, since you paid for the printer and it technically belongs to you. Sometime HP will make cartridges with faulty circuits that the printer will not recognize.. If that is the case call them and demand a new ink cartridge.
Dec 12, 2017 | HP PhotoSmart C4180 All-in-One Color...
Print cartridge in right stall not supported.
I wish I had an answer... Did you ever figure out the problem, because the same thing is happening to me, and I know I'm using the correct cartridges...
Apr 21, 2010 | HP PSC 2410 All-In-One InkJet Printer
Error message "Remove and check color cartridge"
There may be debris that is blocking the communication between the cartridge and the printer. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
Mar 19, 2010 | HP PSC 2410 All-In-One InkJet Printer
Remove and check cartridge in right stall help
Make sure that they are new cartridges.
Also make sure, that you took off the strip off where the ink come out.
Then shut if off, wait 15 min, then turn back on.
Good Luck
Nov 04, 2009 | HP PSC 2410 All-In-One InkJet Printer
Printer shows remove and check print...
maybe it suffered loss connection between the printer and the printhead just try to clean it..with alcohol..or maybe you print cartridge has in it's low ink state..
May 18, 2009 | HP PSC 2410 All-In-One InkJet Printer
2410Xi printer cartridge replaced. still displaying ''remove...''
there are two cartridges in the printer did u replaced both the cartridges ,as sometimes both the cartridges r faulty.and so this message comes.
Nov 14, 2008 | HP PSC 2410 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Hp psc 2410 photosmart check color cartidridge ?
    I'd clean the cartridge connections on the printer, try a new cartridge and refrain from using reinked cartridges.
    Jul 23, 2008 | HP PSC 2410 All-In-One InkJet Printer
    HP PSC 2410 All-In-One InkJet Printer Logo
    399 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
