Question about Sony Cameras
When i open my sony cybershot to take picture, i have only a thin strip down the middle on the angle from left to right, all else is black!! please help!!mNY THanks
  • 10,594 Answers
Kindly intimate Model Number of your Sony Cybershot for further guidance.
Posted on Jul 24, 2008
Sony kdl52xbr4 tv has double vision on right side of screen perfect picture on left side is this a timing control board issue?
Fault with its T'Con board itself. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 14, 2015 | Sony Televison & Video
My brother has a 60" Sony xbr1 year 2006 and the red light blinks when you turn on but no picture or sound. Has a brand new bulb, that's not the issue.
Could be a cooling fan. Sometimes they don't start because of dust buildup. Could be worn out also. I had to replace mine once. Can order via internet.
Nov 14, 2014 | Sony XBR-60LX900 BRAVIA LX900 Series 60 3D...
Camera, Sony cybershot dsc -w55 is taking a '16- photo strip' instead of one photo, any suggestions? Thank You
You're in the "Multi-burst" mode. In the recording mode, press the MENU button, then use left/right to select "Mode," then use up/down to select "Normal."
Dec 09, 2010 | Cameras
I'm having trouble deleting pictures any advice would be helpfull.
normal procedure for deleting images using a dscs700 cam.
1. press playback button (button you use for viewing images, located just above the lcd screen,left side w/arrow icon pointing to the left)
2.salect the image by pressing the left or right control button
3.once image to be deleted is selected, press the delete button (2 black squares w/a slash and garbage can icon,below the control buttons on the left side).
4.select delete option by pressing the up control button.
5.press middle of the control button to confirm.
...or if you would like to just remove everything on the memory stick including protected images you can just format the ms by:
1.press menu to diplay menu settings.
2.press right control button to go to setup (looks like a toolbox or suitcase icon) and press the right control button again.
3.press the down control button to go to Memory Stick Tool and press right again to confirm selection.
4.press right control button to select format.
5.press up control to select ok and press middle control button. message will appear telling you that "all data in ms will be erased.ready?"
6'press up control to select ok and confirm by pressing middle control button.format completed.
hope this info helps. thanks:)
Apr 13, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Dirty lense, out-of-line projector?
in the power supply there are a couple of fuses they are either green or yellow they look like resisters check them with your meter one of them is going to be open replace both.
Mar 04, 2010 | Sony KP-57WS500 57" Rear Projection...
NEED DOWNLOAD FOR SONY CYBER-SHOT DSC-W80, I LOST
Would you like to open your pictures from your Sony Cybershot to your computer? Your cybershot cam is usually plug and play so you dont need a software for that. All you do is to plug in your camera to your computer's usb port using the usb cable. When the computer detected the new usb device, open a Windows Explorer. Right click your windows Start button, and choose Explore. From the list of Drives from the left, you need to find the Drive letter associated with your camera. Just click on that and it will show you the files on the right. The pictures are located somewhere inside those folders. You just need to click and drag them to your computer's local drive.
Should you have any questions, please let me know. Good luck!
Nov 13, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Ink cartridges make a slamming sound from left to right and wont print
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
May 28, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
20" orion tv
The thin strip is possibly a combination of bad parts on your main board. You possibly have a bad horizontal output transistor and or a bad flyback transformer. All of witch should not be repaired by the average homeowner. These sets could have upwards of 30,000 volts inside even when unplugged!! Please dont forget to rate this answer for me ! Good luck!!
Aug 19, 2008 | Televison & Video
Erasing protected pics - Sony Cybershot dcs w-55
Formatting will erase all pictures, including protected images.
  1. Turn on the camera
  2. Press the menu button
  3. Press the "right" pad control button
  4. Then press the "down" to go to Setup (looks like a toolbox) then press "right" again
  5. Then arrow down to the Internal Memory Tool and choose Format by pressing the Center Control Button in the middle of the Control Pad.
  6. or, if you have a memory stick where the image is, select memory Stick Tool and choose Format by pressing the Center Control Button in the middle of the Control Pad.
Hope this helps, if it does, please select FixYa! ThankYa!
Dec 05, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Cameras Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
