Question about Breadman TR2200C Ultimate Bread Maker
Does't move/roatate the blade-it is jammed.
Can you give me solution?
  • 3 Answers
It's probably just frozen. Put olive oil on the inside and coat the bottom of the shaft too, with a solid tool (used a piece of copper pipe with a cutout for the bottom of the blade) work the shaft back and forth, as soon as you get some oil in there it should start to free up.
Posted on Aug 07, 2008
I have a Dewalt DW321 corded jig saw. I can't get the blade to release. The blade blade holder seem frozen.
place the shaft in the fully up position and give the collet holder a tap to move it back up further
sometimes they jam from metal, dust and grit
sometimes a bit of WD-40 or like item will lubricate the movement and make it easy to pull up
Nov 18, 2017 | Dewalt Saws
Can't remove blade on model 25142 mower
Try putting a pipe at the end of the wrench to give move leverage. To stop the blade from turning jam the blade against a 2 x 4 piece of wood to the side of the deck so it is unable to turn.
Sep 28, 2017 | Garden
B&D CMM1200 won't start/blade doesn't spin. Fully charged & it tries to start - blade moves maybe 1/4 inch, there's a "clunk" & that's it. Blade, blade insulator & spacer replaced with no difference.
This suggest that there is something jamming the motor and stopping it from running. Assuming you have checked that the blades are clean and there is no grass build up on the underside, it means that there is something in the motor that is jamming it. This might be something that has fallen into it, or something that has broken. The only way to find out is to pull it apart and check what is jamming it.
May 23, 2016 | Garden
Bosch 4000 table saw motor does not turn, very stiff
Possibly something has jammed inside the motor housing although unlikely.
Electric brake seized perhaps?
Carbon brushes need replaced?
These saws (and the newer 4100) have a history of motor problems, with the field winding and electronic motor speed control being the most common points of failure. If you go to an online tool parts supplier like toolpartsdirect- Bosch 4000 saw you will see a list of the parts available, as well as the most commonly ordered parts.
Thanks go to Jason for his blog post at:
http://mypeculiarnature.blogspot.co.uk/2013/07/bosch-4000-table-saw-fix-momentum-lost.html
May 23, 2014 | Bosch 4000 - 07 Electric Table Saws
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
Unable to get the blade or arbour to tilt to a 45 degree anlge. Will only go to about 43 degrees. Cleaned gear shaft arbour moves on with no success.
First look for a stuck piece of wood in the gear tilt area. The other thing is if you don't tilt it that often the track or swivel can get rusty at the ends. try wd-40 on all the moving parts and you may even have to steel wool the track a little... sometimes as the blade tilts a loose screw will allow it to fall out of alignment jamming the arbor. Turn it upside down with the blade fully retracted and unplugged and see if you can give it a push inside as you tern.-- good luck
Dec 09, 2009 | Measuring Tools & Sensors
Motor runs, but blades dont move
with engine off, take a screw driver and manually move the blades to make sure that they are not jammed. Then spray the blades down with wd-40 oil and they should move freely again.
Jul 28, 2009 | Garden
GE Dishwasher GSD700 not cycling
buy new dishwasher, if you spend the money on the motor plus your labour yo will still have an old one at that and next time something else will go wrong , like the solenoid or timer or circuit board or the impeller seals, etc. Vitally
May 22, 2009 | GE Dishwashers
I managed to locate the vanes and fixed the problem. Thnx for the help on this Board.
Feb 02, 2008 | GE 24 in. GSD2230Z Built-in Dishwasher
HR Specialist
try saturating left over paper with shredder oil and let sit for 4-5 hours or more this should soften paper enough to remove easier although it may be a little messy
Dec 27, 2007 | Office Equipment & Supplies
Breadman TR2200C Ultimate Bread Maker Logo
69 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
