My wireless router works, I set it up correcty, it can be detected and it connects to local area connection, but every time I go on the internet, it tells me that my home page and every other page cannot be displayed. Please help me, I've tryed everything!
    Problem Solver:
  • 17 Answers
Hello licorice4,
It could also be as simple as recycling the DSL modem. Turn it off (either by the switch in the back, or unplug it), wait 30 seconds, and reconnect. Once all of the lights come on again, try your connection.
Posted on Jul 24, 2008
    Scholar:
  • 125 Answers
It seems then that your connection from the pcs to the router is ok but your router connection to the internet is not. If you connect directly to the modem, is it ok?
You must enter your isp logon info into the setup of the router. (especially on DSL connections requiring logon info)
or
There is a cabling problem with your router to your modem. Make sure that your modem is plugged into the WAN port of the router and (if you have one) the WAN light is on.
Im trying to set up my router,i have been using it before but my cpu has been damaged by lightning,sinv\ce then i cant use my router. i followed instructions on how to re configure it,my laptop and pc...
sometimes this router are afected by the lightnings, verify that the internet connection is working well by plugin the internet(ethernet) cable directly to your computer, if it gets connected to the internet we are sure the probleme is isolated to the router.
The easiest way to check if the problem is the router WAN(internet) port would be connecting a known good router just for few minutes
Aug 29, 2011 | Linksys Wireless-G WRT54G Router
Intel 82562v-2 network adapter wont connect to the internet, have searched online and this is a known problem but i cant find a fix. my system is an inspiron 530s and router is a netgear wgr614 but im on...
ok this is a really pretty nice question..
I guess you using windows 7!!
- Click on Start / Control Panel
- Go to Network and Internet then Network and Sharing Center
- On Network and Sharing Center on your Right where its written Task, you will find Change Network adapters. click on it
- Right Click on Local Area Connection / Properties
- In General Menu / look for Internet Protocol (IPV4)
- Double Click on IPV4/ choose use the following IP
Ip adresse: 192.168.0.15
subnet mask: 255.255.255.0
default gateway: 192.168.0.1
Use the following DNS server:
DNS1: LEAVE IT BLANK
DNS2: LEAVE IT BLANK
Press apply and ok
Close everything, your local area connection should show you: "Local Area Network Connected"
Disable your Antivirus and Firewall ( for test ) and try accessing internet it should work
Configure your browser also
IE : Tools / Internet Options / Connections / Lan Settings / Tick "Automatically detect settings"
Ok and try accessing internet.
Firefox: Tools/ Options / Advance Menu / Network / Settings / Tick " Auto Detect Settings for this Network, apply ok.Close firefox and start again it should work.
May 13, 2011 | Computers & Internet
Emachine won't connect to the internet. Ethernet cable, router and modem all work just fine. problem is with computer. Check network adapters in device manager and no problem noted there. Why won't it...
first try to check if your wireless can actually detect a network, if it can try to remove ALLthe network that you have on your wireless network and try to add your network again, if still doest work try to uninstall and re install your wireless driver, if it still doesnt work try to restart your router, if still doesnt work try to do system restore to the point where your wireless was workin fine, lastly if still doesnt work try to contact your ISP for some configuration.
Jun 02, 2010 | E-Machines eMachines Desktop PC
Can't accress the internet as there is no gateway showing
Check whether your pc has static ip's set,
Go to Start/settings/Network Connections/Wireless connections
Click on Properties
Under the General Tab scroll in window to Internet Protocol (TCP/IP)
Next click on Properties
Make sure that both buttons (IP / DNS) are set to obtain automatically
Nov 14, 2009 | NetGear DG834G Router
Wired nor wireless connections for my ps3 wont work
if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Create a local area network
you can get a HP x175 printserver. (not expensive.) and connected it between the printer and the router. that way you don't have to have the desktop on all the time.
Dec 02, 2008 | Computers & Internet
I set up my router, which says it's connected to my computer. I have also set up my wireless on my laptop. It keeps reading that I'm not connected to the internet. The wireless adapter has worked on my...
router internet connection takes more time to connect to the internet,sometimes it took 10mins before it got the connection. make sure 1rst if the laptop was connected to router as LAN
then goto controlpanel ,then networkconnection and rightclick Local area connection,click repair
Sep 14, 2008 | Computers & Internet
Router says connected but I can't access the internet
not like that u dont need to enable local area conn>and correct all teh pysical conn>and reboot the devices and also the pc>rate me solved if its help full
Nov 02, 2007 | Linksys Wireless-G WRT54G Router
Unable to detect my router
This is because your router is setting your pc at a different IP address than your original modem. Make sure router is set to enable DHCP which gives out an automatic ip address and check your wireless card and network cards are set to obtain ip address automatically. It may take a few re-starts to get on the internet as your systems will need to clear their previous DNS settings. Also i assume you have set up the home network wizard (XP) as you are now using a router and not a direct modem. Also try Start>Run, then type ipconfig /flushdns then press enter.
Dec 27, 2006 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
