Question about Kyocera Mita FS 3800 Laser Printer
Kyocera printer hookup to iMac using Ethernet connection
I am trying to hookup my Kyocera FS3800 printer using the Ethernet connection, for my printer does not have a USB connection.
I am using an Ethernet crossover cable to connect the two.
The printer driver is also no problem. I am also using the Printer's IP address.
However, it is not printing.
Can you help. Art
  • artkerber Jul 25, 2008
    I checked the network printing setting in the printer everything seems OK, however, it is still not printing. Here are the settings: TCP/IP = on;
    IP address = 192.168.001.003; DHCP = off; Netware = on; Ethertalk = on.
    Do you have another suggestion? Thanks Art
    Genius:
  • 1,689 Answers
Artkerber, make the IPs almost matching and they should operate on the same subnet mask, and preferably the same gateway address. like this way
Computer settings
TCp/IP = on
Ethertalk = on
IP address = 192.168.001.xxx
subnet mask = 255.255.255.0
gateway address + 192.168.001.001
printer settings
IP address = 192.168.001.xxx ( that if the Mac is 003 make the printer 005 or any number between 2-252)
gateway address = 192.168.001.001
once this is done check your Mac printing preferences make sure it uses LPR printing.
good luck
Posted on Jul 25, 2008
  • 6,487 Answers
Try enabling LPR follow the steps on this link http://it.cas.psu.edu/training/howto/util/AddLPRPrinter.htm
Hope that helps................
  • Kyocera Mita Master
  • 13,433 Answers
Check the network printing settings in the printer, its a problem in the settings somewhere, unless theres a fault somewhere.
Posted on Jul 24, 2008
Can not make wifi connection with printer
If the printer is wifi ready, (you did not post the model number) then most of them require you connect them with a cable to the computer and set up the printer for wifi.
Jan 10, 2017 | PRINTER Office Equipment & Supplies
My Dell 3115cn printer will not connect to the network (it still works on USB cable), hard to believe it's broken, so can the printer system be reset?
Try turning off the printer and disconnecting power plug from wall. Hold power on button for about a minute. Then replug unit and turn power on - it should then attempt to hook up to your existing network.
If no go, try reinstalling the software that initially came with printer and was used to set up the network
Jan 10, 2017 | Dell Office Equipment & Supplies
How do I connect two computers to my Canon MX3520 printer?
in the control panel where you see add a printer, you have to add the printer to each computer then click on the share printer box
Jan 09, 2017 | Canon Office Equipment & Supplies
Can I network Shinco printer s2145
with one of these
http://www.dx.com/p/network-usb-2-0-lpr-printer-server-10-100mbps-ethernet-31570?tc=AUD&gclid=CP-1weaL9MICFRUIvAodEpYAZA#.VKXrgHs_zLk
Only thing is I did not find windows 8 drivers for this printer as standard so you may run into trouble with computers running windows 8 as each computer has to have the exact operating system printer driver designed for its exact operating system .
Unless you can find windows 8 drivers somewhere on the internet
Jan 01, 2015 | Office Equipment & Supplies
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Office Equipment & Supplies
Problem installing drivers for HP 4355 printer in vista 32bit OS
Vista OEM Cd usually doesnt come with drivers.
Printer should have come with its own cd which contains both the software & drivers.
If it didn't come with any
You can try using windows update
or
downloading drivers from hp site
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1138373&lang=en
Feb 24, 2008 | Office Equipment & Supplies
Printer won't recognize cartridge
I had the same problem. I'm not sure but I think I replaced the cartridges when the printer was on because I turned the printer off and removed one of the cartridges. When I turned the printer back on it recognized that cartridge but not the others. I turned the printer off again, rmoved all cartiridges and put them back in when the printer was still off. When I turned the printer on again I had no problems. So...try turning off the printer, rmove all cartridges, then put them back in and restart printer. Hope this works for you .
Nov 28, 2007 | Epson Stylus 2200 InkJet Photo Printer
Samsung kicked out hp 3in 1 printer already installed
Don't have your HP designated as the default printer (if possible)when you hook up the Samsung. When the Samsung is hooked up it sees the HP is the default printer. Well it can't have that, they discard the HP drivers. What does Samsung care about HP drivers theres only one printer port setup and thats the USB port you have them sharing. So yes you need to get a second cable. Tim
Jan 29, 2007 | Samsung SPP-2020 Thermal Photo Printer
Kyocera Mita FS 3800 Laser Printer Logo
215 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
NewYork kyocera HP...
Henry Gertcher
Soulvisitor
Soulvisitor
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
