Question about HP Computers & Internet
Mouse roller ball on mouse is sticking mouse is new
    Scholar:
  • 125 Answers
You can remove the roller for cleaning by untwisting the locking cap on the bottom of the mouse. Usually you have to clean the shafts that are turned by the ball. There are two, one for left-right, one for up-down, and there is a spring loaded roller. There is a gummy buildup on these that prevents smooth operation. I use a sharp knife to gently scrape it off. If the shafts are still sticky you may have to dissassemble the entire mouse. Hardly worth the effort unless you have some kind of high powered mouse with special features. BUT, this is not a symptom of a new mouse.
If it is new and does not work, you should consider returning it.
Also, consider an optical mouse. They do not have this problem.
Posted on Jul 24, 2008
My mouse keeps sticking
is it a male or female mouse? "does it have a light or a ball"
To fix a ball type mouse
Remove the ball and clean the rollers with a pencil eraser
The light type mouse sticking is usually caused due to high CPU usage. To check this right click on the task bar and click start task manager. Then click performance. if your CPU is at 100% then that is why it is sticking.
I would start with a malware scan
Mar 02, 2015 | Microsoft Windows Vista Home Premium with...
Tip
How to Clean Your Mouse
<p><b><span>Roller Ball Type:-</span></b><br /> <p><span>For cleaning your mouse you have to do the following work.</span><br /> <p><span>1. Disconnect the mouse from your computer CPU.<br /> 2. Turn the mouse upside down and twist the roller ball retaining ring in a counter-clockwise direction to remove the ring.<br /> 3. Remove the roller ball from the mouse cavity.<br /> 4. Wash the roller ball with warm soapy water and put it in dry place.<br /> 5. Replace the dry roller ball back into the mouse cavity.<br /> 6. Replace the roller ball retaining ring and twist it clockwise to tighten.</span><br /> <p><b><span> </span></b><br /> <p><b><span>For Laser type Mouse:-</span></b><br /> <p><span>A laser type mouse requires very little care. Internally, there isn't anything required of you. If it should get a little dirty on the outside, just dampen a soft cloth with water and wipe it until it is clean.</span><br />
on Dec 24, 2010 | Computers & Internet
Can I fix the roller in my wireless mouse?
Open the mouse. (Slide the panel on the bottom that surrounds the ball, and pull the ball out. Clean the ball and the rollers inside the mouse with rubbing alcohol. Remove all debris, hair, lint, etc.
Voila!
Sep 26, 2014 | Computers & Internet
My mouse is not working like it used to. I have to scroll two or more times just to go across half of the page
Does you mouse have a ball? If so, it needs to have the ring that holds the ball into the bottom taken off and the tiny white nylon rollers inside the mouse need to be cleaned, I use a toothpick or a wood match stick. The rollers get lint on them, If you have an electronic ( laser) mouse ( like with a red light), it needs to be blown our with high pressure air or maybe replaced.
Be blessed.
Aug 12, 2013 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
I can't control where the mouse goes unless I keep working with it. It's all over the place: kensington orbit mouse 64221. I have taken the ball out and tried to clean it.
It's not the ball that's dirty...
Take the ball out and look in the hole. You will see two rollers that control the cursor movement. The ball spins the rollers. These rollers probably have a bunch of gunk/**** on them. Remove the gunk buildup from the rollers and the mouse will work fine (fingernail is a good tool for this). Turn the rollers with your finger to make sure all the gunk is gone. If not, replace it with an optical mouse (no ball).
Hope this helps!
Regards,
Joe
Jan 02, 2011 | Computers & Internet
My mouse and key board is not working it's an old computer the mouse just moves in direction .upand down.
Probably a bad mouse, I've had this too. Although, if it's an older ball type mouse it might be helpful to clean it. Remove the ball and locate the two roller pins that the ball operates. Clean off the gunk that builds up on these rollers & causes them to stick. Reassemble and give it a try.
Jun 20, 2010 | Computers & Internet
Optical track ball is sticking. How clean it and what to avoid?
An "optical" mouse has *NO* track-ball.
If you do have a mouse with a track-ball, then rotate the "ring" that holds the track-ball inside the mouse, to "unlock" the ring. Remove the ring. Look inside the mouse. You'll see two rollers.
Look for accumulated "gunk" in a ring at the center of each roller. Gently scrape each roller, to clean it. Re-insert the mouse. Re-insert the ring. Rotate it, to "lock" the ring into place.
May 19, 2010 | Logitech 931249-0403 Mouse
Trackball sticks and is sluggish how do L clean it and with what ?
You can pop the ball out. Once you have it out take a q-tip and some alcohol and clean the rollers. You'll notice a lot of gunk on the rollers. Once you do that it's as good as new. To take the ball out turn the unit upside and give it a good shake. the ball should fall out. Be sure to be ready to catch it.
Nov 30, 2009 | Kensington Expert Mouse Trackball
I have a corded mouse on my PC which sticks and flys to the right
A corded mouse can be either an older style with a ball, or newer with the red light. I have found you can take the ball out and clean the rollers inside with tweezers, they eventually get gummed up with lint and such. If it is a red light, most often my problem is a dog hair or something blocking the light. Tweezers work.
Oct 01, 2017 | Microsoft IntelliMouse
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
