Very dark screen
Hi. For some reason when i turn the computer on the screen just stays dark........ I can only see the contents slightly.
  • Anonymous Aug 13, 2008
    have dark screen problem tryed my light button on key board still have problem
  • mjelilaptop Jan 05, 2009
    where is the light button on the IMB T42 , I've truied the F4 button but nothing happens.
    tks for you help
    Champion:
  • 258 Answers
Yuo sud hav light setting button somewhere
Posted on Jul 30, 2008
My mx7515 screen stays dark after I power it up. I can hear the internals working but no screen. I tried hooking up a monitor to it, and that came up with no picture.
First: Make sure after you connected the external monitor to press a combination of key( Fn +[1-9: check for a small picture of LCD monitor] ). If after this no image is displayed on the external monitor then you may need to replace your motherboard. Some local computer shops may be able to fix it. The reason you are having this problem is because the video card is dead.
Nov 18, 2010 | Gateway MX7515 Notebook
Toshiba A105 - S4334 laptop,imediately on startup the screen goes so dark I can't see anything but a shadow of the screen,if I clsoe lid and open again I can see the display but only for a few seconds.Is...
Hello wall flower hi, when you turn on the laptop, did you see the start up screen clearly? can you read words on the screen, and then it goes dark? If this is the case, check first the Fn key with the corresponding display for projector, (usually Fn+F5) this combination key is used to display the content of your computer to the LCD or Projector, IF not such a case, it may be problems with your laptop inverter board that powers the backlight. Check your bios settings also.
Feb 12, 2010 | Toshiba Satellite A105-S4334 Notebook
Screen keeps going into darkness at start-up
Hi
The screen kept winking out because the brightness setting was too dark, something to do with the tolerance perhaps?
I just made it brighter and all was well!
Dec 29, 2009 | Formac Gallery Xtreme 2010 20.1" LCD...
Computer will power up, but FPD 1730 screen stays dark, says "power saving mode" How to cure??
Its setting problem just fallow this stapes for the same.
Go to Start > Control panel > Power options Properties >
Turn off monitor: Never
Turn off hard disks: Never
System standby: Never
Apply > Ok
After that your issue will resolve.
Thanks
Abhay Singh
Nov 16, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
I turn the computer on and the monitor will stay dark even though it is turned on. Then I turn the monitor on and off a few (10) times and eventualy the poicture comes through. I have the monitor hooked to...
It may be caused by 2 reasons:
1. The notebook is not correctly configured for an external display - you may need to install the display drivers or update it.
2. The backlight inverter on the display may have problems and need repairs. Check if you can see a faint image in the screen.
Oct 10, 2009 | Samsung SyncMaster 203B LCD Monitor
The hard drive is good all the lights light up but screen stays blank
Did you accidentally push the Function + (whatever) keys that switch the video out to an external monitor screen?
If the backlight of the LCD screen went bad - you could turn off all the lights - need a very dark room - you could still see the contents of the screen.
Jul 07, 2009 | Sony VAIO VGN-FS840/W Notebook
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
Dark screen, nothing comes out.
Make sure all connections are tight and secure. Troubleshoot like this.
Can you see the boot screen when it boots up( Before the Windows logo appears.)
1. Check and tighten all connections,
2. Possible monitor went out.
Mar 13, 2009 | HP (D7580-60003) Motherboard
Problem with monitor
Hi.
Are you able to see a slight image on it at dusk and maybe with the help of a flashlight. since your blue light stays on the video board, may be okay.
It sounds like you have bad capacitors on your powerboard or possibly a burned out transistor on the inverter.
Only way to really tell is to open it up.
If you unplug the screen to video board ribbon, you may notice a different effect in the screen lighting.
There is a chance one of your bulbs is creating a problem
Should the screen happen to light up all white, then your power board and inverter are okay and the problem may be in the video board.
If it looks pinkish or dark or flickers then the bulbs or a bulb may be the issue.
If it flashes on then goes off, it's in the power or inverter board.
ebaysbammbammfran
Sep 14, 2008 | ViewSonic VX2235wm LCD Monitor
Computer screen goes blank
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After the scree goes dark, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Feb 27, 2008 | Computers & Internet
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
