Question about Garmin StreetPilot C330 GPS Receiver
WILL NOT CHARGE SAID BATTERY LOW AND WILL NOT CHARGE
HAD LESS THAN A YEAR BOUGHT GARMIN BECAUSE IT IS SUPPOSE TO BE THE BEST!!!!
  • LD5153 Jul 24, 2008
    HAD LESS THAN A YEAR WILL NOT STAY ON WILL NOT CHARGE SAYS EXTREMELY LOW BATTERY
  • 174 Answers
Today cars cigarette lighter will not work unless the key is turn on. If the cigarette lighter is working then the unit should power on by itself once you plug it into the cigarette lighter without touching the on/off button. Also once you turn off the engine the unit will do a countdown to shut down once external power is removed from the unit (you can touch the screen to prevent the unit from turning off).
Garmin is still the best unit for the money if you're living in North America. They uses maps from Navteq which is located in Chicago, IL. Tom Tom uses maps from TelAtlas which is located in Amsterdam.
Posted on Jul 25, 2008
I used another charger in house and charged battery must be the car charger adapter I haven't used it yet but I will today and let you know if it works
Trying to charge my Garmin 396 with external power. The unit is showing "Battery Missing". However my battery is there.
I had this problem on an aftermarket battery I purchased last year. It worked well for several months but recently gave me the battery missing warning and would not operate the unit at all. I checked the voltage on my Garmin OEM and on the new one. The Garmin OEM, showed 8.1V on two readings, between the center and right terminals and about that between the two outer terminals. The OEM showed around 5.7 so that implied that it had some bad cells and not a broken wire. I tossed it and bought a new aftermarket unit last week. That one doesn't show a full charge and when I switched back to the Garmin battery it shows 00:00 time remaining, but still 8.1V. Maybe I should have just bought a new Garmin battery!
Jan 28, 2011 | Garmin Replacement GARMIN GPSMAP 396 GPS...
Garmin will not charge. I have replaced the charger cable but still get a low battery message.
Hi pljustice
if you didnt buy a garmin charger, you might of bought one thats not compatible with your garmin, even though they might of told you it was...try to charge it with the USB cable that was supplied with your garmin and hook it up to your computer for a few hours, then try it again and see if it took a charge...the usb cable is the preferred way to initially charge your garmin...if that fails, you probably have a bad usb connector in the gps (very common problem with those)
let me know how you make out.
bill
Dec 22, 2010 | GPS
Only use my Garmin once a year turned it on and it says maps need updating for Florida do i need to do this
There is no need to update the maps unless you want to. The reminder is just to let you know that there are updated maps available and to try to create business for garmin. However if you only use it once a year it's a good idea to take it out more often and charge it up so the battery doesn't run too low and maybe be unable to take a charge again.
Sep 04, 2010 | Garmin GPS
I received a Garmin GPS Nuvi model as a gift for retirement that I haven't used since last year in July. When I cut it on, the screen didn't come on. My question is when I try to charge it up, is it...
you can use the house adapter to charger the GPS.
The GPS should be charged for more than 10 hours because the battery cell must have been weak and it needs a lot of charge for the battery to wake up.
Last year July is really a long time. The battery needs a lot of charge.
Take care.
May 17, 2010 | Garmin nuvi 205 GPS Receiver
Garmin 260 now failing to charge and shuts itself down
If the unit is only a year old? then I would suspect that the charger has a problem that has damaged your battery. Do you use an external power continuously?
Try a different charger or if you have a meter make sure the charger is putting out close to the specs on it. Try using the usb cable to charge it.
The low battery and shutting off are typical of a battery that won't/can't hold a charge. That is typical after 2-3 years plus but not one year. It can also be indicitive of the charging circuit needing to be reset. The problem is it needs to be started and run long enough for it to recognize the reset command. To do this, hold your finger on the bottom right corner of the screen while powering the unit, until it asks if you want to reset it. That might get you running.
While I would be suprised at the battery going out within a year or so it is not unheard of. You may have to replace the internal battery pack. The unit is new enough your only source is probablly going to be Garmin. They might replace the battery under warrenty or out (if you talk nice).
Jul 24, 2009 | Garmin nuvi 205 GPS Receiver
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Jul 24, 2009 | Kodak Cameras
Battery on Nuvi 750
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 19, 2009 | Garmin nuvi 250W GPS Receiver
Zumo 550
my battery failed after less than a year of use. Garmin sent me a new battery and the unit is working fine now. The old battery would not provide ANY power to the unit.
Dec 13, 2007 | Garmin zumo 550 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
180 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
