Question about Black & Decker String Trimmer Cordless 12" 18V
Can't remove casing for B&D Cordelss Grasshog (NST2018 Type 2)
I need to replace some broken parts (spindle not spinning) in my Cordless grasshog and I can't dissasemble the outter shell. I have taken all of the screws out that I cannot get it off of the covering where the head meets the shaft. Does anyone know how to remove this?
  • Anonymous Aug 02, 2008
    I also cannot remove the spool housing (part # 478728-00) that is cracked from the metal piece that holds the guard and guide on my GH-1000 14". I have also removed all the screws only to pull and expose the cable that turns inside the shaft. Is there a trick? I really do not want to take the whole unit apart piece by piece. Thanks.
  • Figaro1 Sep 27, 2008
    I have removed all of the screws from the caseing but at near the shaft the casing will not come apart. It stays as if it was glued or something is holding it. I tired to pray it like it says in this last instructions, but nothing comes loose. Which I had a figure or something to show how it is done or exactly where I am suppose to pry with the screw driver
These are the steps to open the clamshell/motor housing for the Black and Decker 18V Cordless Trimmer Model NST2018. The orange clamshell has two plastic clips that engage two recesses inside the black plastic ring. You use two screwdrivers to disengage the clips and seperate the black plastic ring from the orange clamshell. Follow these steps: Wrap tube assembly in a small towel and mount in a large bench vice securely. You will notice two small openings at the top of the black plastic ring at the top of the orange clamshell. The next steps require two people. Person one inserts a flat-bladed screwdriver into into each of the small openings at the top of the black plastic ring (two screwdrivers). Using the tube assembly for leverage, pry the black plastic ring from the orange clamshell with enough force to disengage the orange plastic clips from the black plastic ring. Person two pulls the orange clamshell/motor housing away from the black plastic ring/tube assembly along a straight line (same axis as the tube assembly). After you've separated the motor/clamshell housing from the black plastic ring, remove the six screws and open the clamshells.
Posted on Mar 14, 2009
  1. There is a hidden screw behind the label on the handle that describes how to unlock the head. The location is in the middle where there is a vertical line. I just pressed with a small screwdriver to break through the label and removed the screw that is probably there to tell black and decker that you have now voided your warranty! But you probably don't have a warranty if you are here!
Posted on Sep 24, 2008
    Problem Solver:
  • 9 Answers
Press the sides in one side or the other probley has snaps on each side or one side or the other
Posted on Jul 30, 2008
  • 3 Answers
Pry with a small screwdriver into the edge of the black piece that locks the head from turning.Pry into the end nearest the spinning line head go around it ,it has one little *** that keeps it from sliding down.you dont have to pry hard just look for the ***. Harry
Posted on Aug 04, 2008
Whirlpool top loader washer model lsr5100hqo details
look for pulleys or belts that trun the drum to see if any are off or broken.
Apr 19, 2014 | Whirlpool Washing Machines
Need Replacement Battery for CST2000
243215-00 is the part number for the Grasshog's battery pack, but that part is now obsolete. However, you can get the internal battery (part #243213-00 )itself from Amazon for $35.99:
http://www.amazon.com/Black-Decker-243213-00-Replacement-Grasshog/dp/B0027Z7G94
Jun 28, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
The washer clunks during spin cycle. I removed the back and found some pieces of plastic from the outer drum enclosure. Other than that, everything seemed to be intact. The "shocks" or feet were not broken...
If the inner basket has broken off on one of the three braces on the back side where it is welded to the main spindle shaft that goes through the outer shell and bearing, you will need to replace the spindle and probably the inner basket. Some come together, some can be bought seperately and bolted. Not sure which yours is. Most people go out and replace unit rather than attempt ths repair because of cost if done by a appliance business. It is a complete tear down, and part or parts are expensive.
If you grab the inner basket and try to move it side to side, it should be solid.. The whole tub assembly can move while your doing this, but the inner basket should be solid in the back bearing
Just one idea..
Jan 13, 2010 | Frigidaire Washing Machines
The motor runs but the base doesn't spin.
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
May 25, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Black and decker 110 volt grasshog
The last time I used the weed wacker it kept stopping-almost like a short. The battery is fully charged and has a lot of power when working. Would the problem be in the handle and can that be taken apart to see if there is a loose wire?
Aug 06, 2008 | Black & Decker String Trimmer Cordless 12"...
My grasshog gh600 wont feed the line anymore. i replaced the cap, spring and purchased a pre-spooled line to see if that was the problem. it wasn't. please assist
check out a white plastic lever at the back of the spool line. if its broken then replace it. cost of the parts around $4.00 or so. this parts controls the auto feed of the spool
thanx
Jun 24, 2008 | Black & Decker String Trimmer Cordless 12"...
Black and decker grasshog
check the white plastic lever location at the back of the spool. replace if broken. less than $3 part
Jun 13, 2008 | Black & Decker String Trimmer Cordless 12"...
Grasshog timer
If you have the model # NST2018 then the only thing wrong is that a .30 cent retainer clip at the upper end of the spindle shaft is missing. A local hardware store should have one that will work. There should be a thin washer that will go between the sleeve bearing and the retainer clip that will be inside the housing as well.
Jun 12, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
1,092 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
EugenesDIYDen
EugenesDIYDen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
