Question about Sharp Televison & Video
On my TV certain shows (Craig Furgerson, Oprah, The View)on different networks,a black rectangle, about 1/3 of the picture, appears. I cannot remove it.
  • Anne Cowan Jul 24, 2008
    I own a Sharp TV Model LC-32AV22U
    Thanks for your help. It worked.
  • Sharp Master
  • 13,433 Answers
Heres something I found for you to try
Quote
moskilarock
just solved the problem for the Sharp Aquos black box. The menu button on the remote only lets you set up the cc. The bottom of the remote has a little door, open that and there is a cc button. If you press cc, a little box will appear on the screen, one of the lines tells you the size of the box. Scroll to that line, keep hitting the cc button until it says off. I had to do it for a few stations individually, but the problem appears to be solved.
Posted on Jul 24, 2008
  • Ekse Jul 25, 2008
    You need to press "accept" on the solution which solved the problem.
    Thanks,
    Ekse
    President:
  • 2,267 Answers
That box appears to be from the close caption feautre. If you have the original remote you can disable using the menu and go to audio functions and look for close caption to turn it OFF.
Do you have the user's guide for this TV?
If you do not, could you provide the model number of your TV?
  • Jaime Hernandez Jul 24, 2008
    Click here to download the user's guide and go to page # 27 to turn close caption OFF. You might have to do it for every channel that is giving the CC box.
    Would be please be able to rate the solution that worked for you?
A black rectangle showing in the middle of the screen this appeared suddenly
this sounds like screen burn with rear projection and plasma when a picture is left sitting still on the screen sometimes it will burn in to the screen rendering it useless i left my ps3 paused on my old tv then when i changed to bbc one it still had a faint call of duty pause screen in the back it can vary from things like that to logos to your black rectangle the only way of repair is by replacing the screen all toghether i would advise you to just take the screen off and start using the tv as a projector if you cant find a screen it is only a bit of ribbed plastic but very hard part to find
Feb 16, 2011 | Toshiba 46HX83 46 in. Rear Projection...
Issue with our Toshiba 50H82 - overnight it has stopped playing DVD's properly - a solid black rectangle obliterates 75% of the screen. Any idea?
Do you see same solid black box in all inputs or just in dvd picture?
If solid box appears only with dvd picture then its generated by dvd player, check dvd player Menu and turn off any subtitle settings.
And if solid black rectangular appears in all inputs of TV like cable etc then check Close Caption feature in TV and turn off CC function.
Hope this will solve your TV problem.
Thanks.
Nov 29, 2009 | Toshiba 50H82 50" Rear Projection...
Part of Picture is black
chances are your close captioning has been turned on go into cutomer menu setup and see if it on.
Oct 26, 2008 | Sony KP43T75GRAY 43" Rear Projection...
Older model sharp tv G1018CESA large solid black rectangle on top of picture dont know how to get rid of? if i change channels can see full picture but rectangle pops up in seconds
Go into the menu and turn off closed captioning. You have accidentally turned it on to text or cc1 or cc2, but that is positively what is wrong. Good Luck! Please rate this solution!! Thank you,
barneyluc
Oct 06, 2008 | Televison & Video
Mitsubishi 1995 cs31205 32 inch tv
Good Day;
Sounds like you have the TV in the "close caption " mode (text), turn off. 2. Check batteries and the mode the remote is in; eg TV, VCR, Cable & ect. Good Luck, big IRISH.
Oct 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Black insert/rectangle
T he text mode in the closed caption is turned on.
Turn off the closed caption.
I don't have the schematic in front of me, so, I will try from memory.
There may be a button on the remote that says CC, if so then use that button to turn it off, if not then go to the customer menu and you may have to search a bit.
Either way it's an easy fix and you can do it yourself.
I f you can't find it, then, reply and I will give better instructions when I get into my shop next week.
Dec 09, 2007 | Panasonic PT-43LC14 43" Rear Projection...
62' Mitsubishi WD-62525 little black and white squares instead of picture but I have sound
Mitsubishi list this problem and has a solution of replacing several small surface mounted caps and diodes. we have tried this repair 5 times and only successfully done it once. so replacing what is called the formatter board part # 930B924002 for around $ 350.00 usually repairs this type of failure, However changing this board is a time consuming thing and takes a lot of Patience. It is buried deep in the set and several other board have to be removed just to get to it
Oct 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
