Question about Kenmore Oasis HE 27082 Top Load Washer
OASIS 110.2706.2602 It does not spin and rinse the water.
  • 41 Answers
Check the pump for blockages
Posted on Jul 24, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore 110 Series 90 stops at the rinse cycle full of water
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. hence, the reason why you can get it to work sometimes by lifting and closing the lid. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually cost between $25 and $35. I hope this helps you. Let me know if you require further assistance.
NOTE: For future reference, it is strongly recommended that you do not slam the washer lid or place heavy objects on the lid. This can cause damage to the lid switch.
Posted on Aug 19, 2008
SearsTechToo
  • 261 Answers
SOURCE: Kenmore Oasis Elite---110-27086601
This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
Posted on Sep 12, 2008
  • 16 Answers
SOURCE: Doesn't drain water and spin
It sounds like your drain pump is either clogged or bad. Bail out as much water as you can with a cup and then check the pump. There will probably be something in the pump stopping the impellor blades. There will also be alot of water so make sure you have towels and/or a bucket when you take the pump off.
Posted on Jul 06, 2010
emissionwiz
  • 71043 Answers
SOURCE: Regarding Kenmore Oasis mod. 110 27072600 Ser.
LF is a failed water inlet valve either hot or cold sets the code, try using just hot then just cold settings and see if the code goes away, if it does then the hot or cold water solenoid valve at the back of the washer is defective
Posted on Sep 16, 2010
Macmarkus
  • 2605 Answers
SOURCE: I keep getting the OL message on my Kenmore Oasis
Hello, welcome to FixYa.
I'm pretty sure I know what you're referring to and contrary to what has been posted by another FixYa memeber, it likely is not the motor assembly...more often it is just an item stuck under the basket/drive hub as most with REAL experience would know.
In fact I can explain what needs to be done to gain access and repair though it is pretty involved (via removing the tub...it's pretty easy once you see how...much easier with the manual and some guidance).
As I alluded to, it is most likely the drive/spin basket hub under the inner basket (spin basket) and it is being jammed by a sock, undergarment or the like, but you'll need to remove the complete outer tub assembly unfortunately.
This almost always manifest's in the "oL" error code (possibly even error "UL" & "F51") and prevents proper wash or spin...though it usually will certainly fill and drain O.K...unless the error appear's many times it may simply go into a shut down/no action (F1) mode.
I can provide a follow up post on how to do this, including pictures and step by step guidance if you think you are capable, or I alternatively can provide you a service manual if you post an email address.
I'll watch for your reply. Thank's for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Oct 18, 2011
Kenore Elite Oasis top loading washer wont spin during the spin cycle, but will rotate during wash and rinse cycles
Since the motor turns regadless of the direction it turns itself is good and theirfore the problem with your washer i believe is going to be the control board,it is what tells the motor what direction and what speed to turn.
GENE
Sep 23, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Regardless of how big or small the load is right around the time for the washer to rinse and spin it just hums and then the Ld light starts to flash, however if I restart and do a rinse mode it completes...
Verify that BOTH hot and cold taps are turned on. If one is off, the machine will buzz (inlet water valve, with no water present) and wait forever for water to fill.
May 04, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Machine stopped in the spin cycle, now only makes noise.
Be sure BOTH fill hoses are hooked up and TURNED ON. What happens is (commonly) hot and cold hoses are installed reversed, and no one really notices.....Then Dad gets a big hot water bill and turns off the HOT water (actually hooked up to the cold input on the machine), so when the machine gets to the rinse cycle, no water comes in, and it waits patiently (forever) for water which never comes. The buzzing is the water valve. This is the most common problem.
Dec 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
Feb 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
On any cycle you put it on including rinse/spin
Call recall # 1 800 659 7026. Give your name & telephone # you gave when you purchase it. Some CS reps want model & serial #. Your machine is probably part of the recall & will be repaired free if it is...Good luck!
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer is skiping rinse and don't spin has code ol
be sure that both water sources are connected and turned on.
Sep 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Multiple Errors & unable to turn off
You probably have something in your pump. if the water didn't drain best bet is to check pump.
Jan 08, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
93 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
