Question about NetGear RangeMax WPN824 Router
No internet connection
I have an orange internet account. I used to connect through my PC and a speedtouch adsl modem. I recently bought a macbook and the netgear router wpn824v3. I can log in to the router from the macbook (wirelessly) but when the smart wizard runs it says I have "No internet connection". If I unplug the adsl line from the router and plug it back in to my speedtouch I can connect to the internet through my PC, no problem. The username and password are correct too. This has me stumped. I've already tried manually inputing the DNS Server addresses but with no joy. Help!!
  • 2 more comments
  • AcidCatFish Jul 24, 2008
    Tried the solution you suggested. I've input the basic settings manually but to no avail.
    Tried your suggestion but to no avail.
    Okay. The expenses for your cocaine and hookers lifestyle is probably a little too high, you're right ;-)
    I'll try everything from scratch again. Does the password 'type' matter?
  • AcidCatFish Jul 25, 2008
    Thanks Benimur, I'll give that a go and get back to ye.
    Brigadier General:
  • 6,966 Answers
Try the Speedtouch ADSL modem direct to the macbook. No NetGear Router (powered off). Verify that the macbook could surf/browse/connect to the Internet. Get the IP Add, Subnet Mask, Default Gateway and DNS assigned to the macbook. Write this down. Disable DHCP of Speedtouch.
Disconnect the Speedtouch from the macbook. Connect Netgear Router to macbook (WiFi or wired/LAN). Log into router. Do not run Smart Wizard. In WAN/Internet/Modem setting of router enable/check static IP Add. Use the IP numbers previously assigned to macbook that you have written down as the routers WAN/Internet/Modem IP settings. Save and reboot router. Connect Speedtouch to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 24, 2008
  • 19,396 Answers
Contact Orange technical help number, an operator will follow you step by step in setting up the network again, here are numbers for UK :contact us about your Internet account
Let me know if you need number for a different country.
  • 1 more comment
  • Ginko
    Ginko Jul 24, 2008
    General broadband support number in UK is :0844 873 8586
  • Ginko
    Ginko Jul 25, 2008
    Orange broadband does not support static IP , at least in UK, I am working on it every day.
    Call your technical one to one customer service, the problem would have been sorted by now.
    You cannot just manually input any DNS, must be DNS for your Area and you ISP. You cannot just chose between dynamic DHCP and static , you are just messing up things more and more.
    Tell us your country to get right phone support number.
    You need to follow instructions to set back right parameters on router, and about MAC just remove wireless networ created sure that is a complete mess as well.
  • Ginko
    Ginko Jul 25, 2008
    First of all, what does it means? " If I unplug the adsl line from the router and plug it back in to my speedtouch I can connect to the internet through my PC"
    HAs the router even worked on this broadband, If you havent been able to connect the router to broadband yet it is mandatory to call provider, it is what everybody does, unless you call a technician, you need to input right parameters into router!!!!!!!!
    My suggestion:
    After a couple of days troubleshooting you should have fixed or diagnosed a faulty router or a problem in MAC configuration.
    If you still have wireless internet on router, (you can connect to different laptop), try following
    • reset router
    • re enter router serrings (call Orange if lost)
    • Create new wireless network on router (ask if you don't know how) with no protection for now, called "newconn"
    • remove wireless connection on MAC
    • stop MAC firewall,
    • Create new wireless connection on MAC to "newconn"
    If it does work change network settings on router to protected wireless, and add key on mac.
    If it does not tell us where you leave and call Orance number, to reset your router.
    Generally, when it takes over one hour to fix this problem there is something wrong with hardware, in your case it seems more of a confusion in setting up MAC and router. Check it out
    Check: Wireless Computing for Macintosh OS X Laptops
    How to connect your OS X Mac to a wireless network - Simple Help
    Check also how to reset orange router.\
    If you give us location (eg London) we can find some of the parameters (DNS and more) to set up broadband on router, better to call ISP by the way.
  • 13,433 Answers
The settings in the netgear are wrong.. make sure you plug the adsl into the internet port and other devices into the other ports.
  • 3 more comments
  • Ekse Jul 24, 2008
    http://kbserver.netgear.com/kb_web_files...
    see the separate network connector, connect that do the adsl directly.
  • Ekse Jul 24, 2008
  • Ekse Jul 24, 2008
    Connect modem to the modem port, and your computers to lan ports. then do a reset
    Hardware reset: Push the reset button on the back of the router for 15 seconds.
    it should automatically start working in a minute or two.
  • Ekse Jul 24, 2008
    obviously your doing something wrong or there is a problem in the settings, best thing would be for me to come over, but I suppose you won't be intrested in paying the airplane tickets + hotel + special services that I require.
    I would suggest get a local professional to come over and fix the settings for you.
  • Ekse Jul 24, 2008
    Heh :-)
    Password type.. your wireless devices need to all support the same encyption wep128 for example is a common one and should be supported by all your devices. also you need to configure it on every device.
  • 1,183 Answers
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Thanks
proton
How can I obtain a user guide for Acatel optus one touch 250 P/N16513 corded phone?
Optus Network Approved modem and equipment list
If you are supplying your own DSL modem and/or telephone filters, you must ensure they meet the requirements
below before connecting them to the OptusNet DSL network. Connection of unapproved equipment is prohibited.
The modem list contains equipment that has been certified by manufacturers as having passed interoperability tests
r
equired for use on a DSL network. If your modem make and model isn't listed below,
call Optus Customer Service for further information on
1300 309 333.
F
ully supported by OptusNet DSL Broadband Customer Service, the OptusNet DSL Broadband Installation CD-ROM will automatically
c
onfigure this modem.
D-Link ADSL Modem 302G
The OptusNet DSL Broadband Installation CD-ROM provides detailed information to manually configure these modems, and OptusNet
DSL Broadband Customer Service will provide limited connection support for them.
(Equipment Certification date in brackets)
F
or modems and routers other than those above, OptusNet DSL Broadband provides only the network connection settings needed for
manual configuration. While this equipment can be used on the OptusNet DSL Network, no OptusNet DSL Broadband Customer Service
will be provided for connection configuration or equipment-related connection difficulties.
Alcatel SpeedTouch - 510 ADSL Modem (15.01.2003)
Alcatel SpeedTouch - 530 ADSL Modem (15.01.2003)
Alcatel SpeedTouch Pro - 4 port (10.09.2001)
Alcatel SpeedTouch Pro - Firewall (09.10.2001)
Alcatel SpeedTouch PCNIC (04.08.2000)
Alcatel SpeedTouch USB (04.08.2000)
Askey/Dynalink - ALE 070 (08.01.2001)
Askey/Dynalink - ALH 110 (21.03.2001)
Askey - RTA100 ADSL Modem (25.10.2002)
Billion Electric - BIPAC-711 CE ADSL Modem (25.10.2002)
Cisco WIC - 1ADSL-DG (30.06.2003)
Cisco 827 (19.02.2001)
Cisco 827H (11.07.2002)
Cisco 827-4V (19.02.2001)
Cisco 837 (01.04.2003)
Cisco SOHO77 (29.11.2001)
Cisco SOHO77H (11.07.2002)
Cisco SOHO97 (01.04.2003)
D-Link ADSL Modem - DSL 100D (08.08.2001)
D-Link ADSL Modem - DSL 500 (08.08.2001)
D-Link ADSL Modem - DSL 504 (08.08.2001)
Efficient Networks - C10 Communications - Speedstream 3060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 4060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 5260 (08.01.2001)
Efficient Networks - Siemens - Speedstream 5400 (07.04.2003)
Efficient Networks - C10 Communications - Speedstream 5660 (21.03.2001)
Efficient Networks - C10 Communications - Speedstream 5667 (10.09.2001)
Efficient Networks - C10 Communications - Speedstream 5861 (21.03.2001)
Juni NetAce - ADSL USB Modem (15.01.2003)
Juni NetElite 2000ES - ADSL 4 port Modem (15.01.2003)
Juni/Samsung SAM-215 USB Modem (18.07.2001)
Juni/Samsung SAM-335A Ethernet Modem (18.07.2001)
NetComm ADSL Modem - BusinessSmart (08.08.2001)
NetComm ADSL Modem - USB - NB1200 (27.08.2002)
NetComm ADSL Router Modem - NB1300 (20.11.2002)
Open 501r ADSL Router Modem (05.04.2002)
Alcatel - Central, Part No. 3AU 04804 AAAA
Alcatel - In-Line, Part No. 3AU 04805 ABAA
Askey/Dynalink - In-Line, DT60-002BA
C10 Communications - Dynamic - In-Line, C10290
C10 Communications - In-Line, C10611 & C10611T
C10 Communications - In-Line, C10645 & C10645T
C10 Communications - In-Line, C10610
Te
l
ephone Equipment - Central, TE-ACP20AUS01
C10 Communications - In-Line, C10211
C10 Communications - In-Line, C10111
C10 Communications - In-Line, C10145
C10 Communications - In-Line, C10245
D-Link - Central, DSL-10SP
D-Link - Central, DSL-10CF
D-Link - In-Line, DSL-10MF
Alcatel SpeedTouch Home
D-Link ADSL Modem - DSL 200
D-Link ADSL Modem - DSL 300
D-Link ADSL Modem - DSL 300+
D-Link ADSL Modem - DSL 302G
Optus supplied modem
Optus preferred modems
List of all other certified modems/routers
List of certified filters/splitters
Information correct as at 2 February 2004.
1270049 06/04
Nov 12, 2014 | Cell Phones
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
Apr 01, 2010 | Computers & Internet
I have a DSL502T ADSL Router,and have bought a new emachines computer. I can not connect to the internet. The computer has a wireless connection loaded but I want to connect by dailup Please could you help...
You are a bit confused with the various components required for Internet connections.
If you have a dial-up connection with an Internet Service Provider, all you do is connect your computer's modem port to the phone line and dial the phone number of your Internet Service provider.
If you are connected to the Internet Servise Provider by ADSL and have a combined ADSL router and modem then you connect the phone line to this router/modem. If the ADSL modem is separate component then the phone line is connected to the ADSL modem and this modem is connected to the router with a LAN cable and the computer is connected to the router with another LAN cable. If the route is wireless and the computer has a wireless card then you don't need a LAN cable between the router and the computer.
If you are connected to the Internet by ADSL, to secure your Internet connection and configure your computer so it can connect to the Internet, please follow my instruction - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 17, 2009 | Computers & Internet
Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
May 19, 2009 | Zoom X6 Adsl Modem/router Rohs...
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
DSL Flashing
You dont need both. Do the following:
Unplug your speedtouch from the phone line at the back of the speedtouch unit. Plug that cable into your Zoom. Then plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Nov 23, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
USB Modem V ADSL Router/Modem
Unplug the plug (from phoneline) on back of USB modem, plug into Zoom router. Plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Aug 12, 2008 | Zoom X6 Adsl Modem/router Rohs...
Wireless router does not connect to the internet
While you have the router connected to your modem, try unplugging the modem and plugging it back in. This will force the modem to redetect network connections.
Apr 15, 2008 | D-Link Air DWL-122 802.11b Wireless...
Buffalo airstatio whr-hp-g54 router unable to connect to Orange speedtouch
I think the speedtouch modem do you have is a usb modem connection. The best solution is to call your ISP provider and request that you need to replace the usb speedtouch modem to LAN or RG45 connection. But the only problem you encounter if the internet you applied is personal only sometime they cannot provide the LAN connection to personal connection (like globe ISP).
Apr 08, 2008 | Computers & Internet
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
NetGear RangeMax WPN824 Router Logo
232 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
