Oven accidentally operated without any contents and cut out with a smell of burning. Subsequently the oven only runs for approximately 22 seconds before stopping. Any ideas?
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
This can be caused by grease etc. inside
the oven and on the wave guide which is the paper like thing in the oven. If
you can remove it look for burnt areas which may can be scraped off or you may
need to replace it. An appliance parts store usually has the material you can
cut to fit you own.
You need to stop using your microwave if it's burning. This is a common symptom of a blown magnetron. Using it in it's current condition is not only dangerous, but it will further damage other components in the high voltage circuit and/or waveguide. In many circumstances, damaging the waveguide renders a microwave non-repairable. A new magnetron will cost you around $100 if you wish to repair this yourself. NOTE: I would not recommend working in or around the high voltage circuitry unless you absolutely know what you are doing. Do not attempt to take any live voltage measurements or operate the oven with any of the protective covers removed or interlocks defeated. Voltage potentials of over 13,000 volts exist and are potentially dangerous. I hope this helps you.
In principle no it is not hazardous.
In practice however, unless the machine is clean to the point of sterile, small items in the microwave can absorb more energy than they would if a large item was in the machine also. This can produce some damage to the machine.
manufacturers generally recommend not running microwaves empty.
Why would you want to?
If in doubt, just a cup of water would be more than adequate.
it is not a good idea to modify a microwave oven in any way.
Hope this helps :)
