Question about Honeywell Heating & Cooling
We have a Honeywell Chromotherm III thermostat and it has an error message "-AC". No fan, AC, heat, etc. Any ideas?
  • 828 Answers
I almost think you have no power source to the thermostat as if the power is off to the air handler unit (furnace), or the 24 volt transformer is bad. Could well be that the error codes are being powered by the battery.
Posted on Jul 24, 2008
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
Mar 02, 2017 | Heating & Cooling
Honeywell Chronotherm III Thermostat shows time of day-AC. No heat in the 2 zones with this message.
Hello,Message AC means that there is no 24volt power to the thermostat from the unit/s it controls.Please check all switches & curcit breakers to the unit/s as there is no low voltage power to the thremostat from the transformer in the unit/s.Maybe got turned off by mistake.
Nov 01, 2010 | Honeywell Electronic Programmable...
My honeywell chronotherm III says -AC any ideas
The problem is your 24v power source. I am unsure as to why you put "other than power source or batteries". If you did indeed check that your thermostat is receiving 24v, then I would say that you have a bad thermostat. Hope this helps
Jan 22, 2010 | Heating & Cooling
My furnace has stopped working. the thermostat (Honeywell Chromotherm III) displays HOLD - AC. What does this mean? I replaced the batteries but nothing has changed.
Try to find a reset button or just change out the thermostat. I'm guessing you don't have the manual. Thats a pretty old model, I think you have to set the time and day before you can use the thermostat.
Dec 29, 2009 | Honeywell Programmable Thermostat Heater
Inaccurate current room temperature reading
It is not adjustable, sounds like the LED is going bad. Tstat has battery back up for power outages. If you slide the fan switch from auto to on does the blower motor start? If not control problem with unit.
Jan 22, 2009 | Honeywell Programmable Thermostat Heater
Replacing aging erratic honeywell chronotherm III
Hi, your replacement part can be purchased on amazon, take a look here: Amazon com honeywell chronotherm III thermostat. I hope this was helpful. Cheers
Nov 30, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
269 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
