Door seal replacement
How do I replace the door seal on Bosch classics 1200 WFL 2463GB/12 FD washing machine
  • palale Apr 08, 2009
    reverse the process? Does this mean you have to try to put the rubber on the door whilst attaching spring at the same time? I have been trying for hours and getting very frustrated. the seal doesn't appear to fit?
  • Washing Mach... Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Posted on Jul 22, 2013
1 Open filter cover and remove screw,slide plastic to right and remove.
2 Remove 2 screws from door hinge,lift and remove door.
3 Remove spring tensioned wire from groove in rubber door seal and ease rubber off front cover
4 Remove soap dispenser and remove the screw this reveals.
5 Remove 2 screws from bottom of front cover.Push cover upwards and remove.
6 Place to one side being careful not to damage wires to door switch.
7 Remove spring holding rubber to drum and ease off rubber door seal
8 Replacement is a reverse of the above
Posted on Jul 27, 2008
Mould inside rubber seal
Bosch Axxis WFL 2060 Front Load Washer mould on door
gasket.
This video will show you how to change a door seal on this Bosch front loader washing machine.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Classic 1200 not working key sign stays on
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Sure we know how to unlock it, but rate me 'very helpful' for the free help, thanks
May 04, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Front seal leaking in my bosch exxcel 1200
This video will show you how to change a door seal on this bosch bosch exxcel 1200
Mar 28, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I get lots of mould on the door seal - why? The machine also leaks when its empty or only half full
You won't notice the mold on other machines with black door seals because of the color. If your seal is gray, it is a normal thing. Chances are it really isn't mold, but a build up of crud. However in the off chance it is mold, spray the seal liberally with mildew remover, let sit and repeat until the mold is gone. . As for the leaking (assuming the leak is happening at the door), if it is a drip or two during the cycle, although it is not "normal" for this to happen, front loaders do often drip here and there. If you have more problems than a couple of drips, replace the seal. . Other leaks not at the door should be looked at. There aren't too many places it can really leak. It should be easy to find.
Nov 25, 2009 | Bosch Classixx WFL 2066 Front Load Washer
I need to change the door seal on a bosch washing machine is it tricky
This video will show you how to change a door seal on this Bosch Classixx WFL 2066 Front Load Washer washing machine
Nov 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Axxis WFL 2060 washer leaks
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Mar 08, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axiss washer front door seal replacement
Remove the top of the machine(screws are at the back).
Look down the side of the front door on the inside of the machine.
You will see a metal wire band holding the rubber on.
You usually only need a screwdriver to loosen the screw which holds it tight.
Try it out and get back to me if you get problems
good luck
Jan 31, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Fitting washing machine boot gasket/door seal
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
May 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing machine replacement door seal
This video will show you how to change a door seal on this bosch Axxis WFL 2060
Oct 26, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
1,363 people viewed this question
Top Washing Machines Experts
