Question about Dell Latitude D600 Notebook
Dell Latiture D600 Touchpad not working!
Well I just acidently spilled tea over the laptop, asap I plugged the battery out and opened the laptop up , shook it and put it in the sun, after that I used a hair dryer and then I put the keyboard back and turned it on, itworked , keyboard was workin fine but the mouse pad and the buttons were not workin. Then i restarted it and it started workin but afte a couple of minutes the mouse arrow started poiting towards up constantly and then I restarted the system and mouse pad and its buttons stopped workin,
Please helpme, I need to use the mouse pad urgently, I need help, what can be done or what should be done,
  • nabeel08 Jul 25, 2008
    The thing is that my problem is fixed,
    it was more of hardware problem, the tea got dry inside the laptop causing short cuircuit in the contacts inside especially the touchpad, once got cleaned by my roommate, a master electronics engineer, now its working perfect, I do appreciate your help and support and keep up the good work and also for trying to help.
    Guru:
  • 859 Answers
Have you downloaded and installed the latest glide pad drivers from Dell?
Upon starting your laptop I would enter the bios setup screens and navigate the startup screens using Alt+P to find the pointer settings and set your or check that yours is using Glide Pad only, If you so choose to use an external USB travel mouse, this setting must be changed to Serial only.
Once, you download and install the latest drivers for the Glide Pad, and by the way, the Glide Pad on the D600 series is its only weak link in an otherwise best in class laptop.
To access the sensitivity settings for your Glide Pad after installing the new driver or in your case this may be reinstalling (I have to do this way to often) open Mouse within Control Panel and the last Tab is your Glide Pad. Here you can change a lot of the property values for things like sensitivity and double tap scrolling etc. Your mention of the mouse traveling up and to the right in most case is normal for this laptop.
Here is the link for the Glide Pad driver update. If this link has expired, here is the permanent location. Just click on the download button on this page. Download and move to a unique folder as the file name won't be of help. Move to something like c:\software\Dell\Glide Pad\
Regards,
Worldvet
Posted on Jul 24, 2008
  • Glenn Rogers
    Glenn Rogers Jul 25, 2008
    So, if I may ask, what didn't work for you when you tried my solution you didn't leave any feedback so I can take you to the next step in troubleshooting.
    We are here to help you get through you problem by starting with the most logical approach and then taking it to the next level.
    Since you were able to get your laptop's writ rest off and keyboard I felt confident we could solve your problem if you were to work with me on this.
    And, just of the record we or I in particular don't try to do anything I and most of us with the higher rankings will work with you until there is a solution that concludes to your satisfaction or there is nothing else to do but replace a part.
    Those of use who work in the free area forum expressly do so to gain and earn a fixed solution. thanks for trying is not really appreciated. I'd appreciate you at least removing it as I don't try anything I fix things and have for over 25 years.
    Regards,
    Worldvet
I've got same laptop Dell C600 is the same specs as D600 only the speed is different!!
there's 2 things you can do:
you can disabled the touch pad through the registry press START/control/Administrative tools then click services
look for mouse pad then choose disabled, this will alow to to use an external mouse insted to get round this problem you have
Do you use Windows XP Service Pack2?
richard west: richard_west_8@hotmail.com
Erratic keyboard
Sounds like an driver update needed to your touchpad software. Did you by any chance spill anything into the keyboard. We are computer service company that offers remote free diagnosis. Call us to today at (877)608-4574 or visit us at www.aplusonsite.org.
Aug 08, 2014 | Dell Lattitude D600 Notebook
My touchpad can not click after a spill.
your keyboard is scrapped......go to the nearest service center.....(if you have a warranty) this wont be covered in the warranty you have.
Dec 27, 2013 | Acer Aspire Computers & Internet
Spilled tea on keypad of macbook now it doesn't work
Open laptop and lay on heavy towels with the keyboard facing down, remove charger and main battery, most of the tea should drain out in this position, contact a service centre to assess the motherboard, sooner the better.
Jun 17, 2012 | Apple MacBook Pro Laptop Computer with...
My touchpad does not work for some reason so I need to plug in a mouse pad to use my laptop which defeates the purpose of a laptop.
reset all bios settings, remove battery for some time and reinsert it, then run reginout cleaner and then check it may work
Oct 29, 2010 | Dell Latitude D600 Notebook
I have Windows 7 on a Dell Inspiron lap top. My
Update the driver for your Keyboard/Touchpad. Got to Dell's Download Page. Enter your Service Tag, underneath your laptop, to get the correct list of drivers for the corresponding model of your laptop. Make sure to select the correct operating system. The touchpad drivers are located in the Input Device Drivers section, listed as Dell Touchpad / Pointing Stick, Alps - Driver or Synaptics - Driver.
After installation, go to the Windows 7 Start or Orb then in the
type main.cpl, click main.cpl in the list of programs.
1. Click the Dell Touchpad tab.
2. Click Touchpad Settings.
3. Make sure there is a check in the box to the left of TouchCheck, move the slider bar all the way to the right (this can always be adjusted back).
4. Uncheck the box to the left of Tap to Click.
5. Move the slider in the Touch Sensitivity area to the right until it is 3/4 of the way toward Heavy Touch.
6. Click Apply, then click OK.
7. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
Jul 16, 2010 | Dell Inspiron 1525 Notebook
Spilled coffee on D600 notebook, power supply turns off when plugged in after had the notebook cleaned. is my notebook not fixable?
When the power supply turns off when plugged into the laptop it is indicating that there is a short. Remove your battery and try connecting the power adapter again. If the problem persists your motherboard will most likely need to be replaced.
There are companies out there that will repair motherboards however if the laptop was on when the spill occurred there is little to know chance that the motherboard is repairable.
Mar 16, 2010 | Dell Latitude D600 Notebook
Water spilled into my laptop Dell Latitude D600. what do i do
  1. Disconnect any power and remove the battery
  2. Tilt the system in various angles to drain as much of the water from the system as possible.
  3. Let the system dry for several days, (I'd say a minimum of 4) is a relatively warm place
  4. Insert Battery, see if system will power on.
If the system was powered on when the spill occurred and turned off by itself during the spill, then the motherboard has most likely been damaged and will need replacement. ($100 or so on EBay)
If the system will not power on after drying, you might consider replacement rather than repair as the cost of fixing it could exceed the replacement cost. (Dell has portables starting around $399)
http://www.dell.com/us/en/home/notebooks/laptop-inspiron-1545/pd.aspx?refid=laptop-inspiron-1545&s=dhs&cs=19
Dec 24, 2009 | Dell Latitude D600: Pentium M 1.6GHz,...
My Dell Laptop battery doesn't work if its not plugged in
You could replace the cells in the old battery if you want to bother opening it up, getting new cells, soldering them together and resealing the case. Unless you're used to doing that kind of work, it's probably not worth it.
But it appears that the battery has reached the end of its life, so nothing you do to it will make it work again.
Sep 10, 2008 | Dell Latitude D600 Notebook
Dell d600
I would completely disassemble it (it really isn't that hard), let it dry out, then put it back together and see what happens.
May 03, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
KEYBOARD HAS A MIND OF ITS OWN!!!!
I have had this same problem before and it happened after I spilled tea (with sugar), on my keyboard. It may be that the prior owner spilled something on the keyboard. This can be fixed by ordering a new keyboard (the plastic circuit board), that fits underneath the actual keyboard. They can be purchased through Dell or Ebay and take about 10 minutes to install.
Jan 23, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
7,312 people viewed this question
Alun Cox
