Question about Frigidaire ATF6000ES Front Load Washer
Fridgidare Front Load Washing Machine
Have an EFO error code on my washing machine and we can not seem to figure out what it means? Thank you
  • Anonymous Sep 30, 2008
    i have the same issue too. error code EFO flashes when i use warm or hot water.... this is so annoying and starts in the last bit of the cycle and continues after the load is complete
  • 876 Answers
It means one of two things. You either did not use an HE detergent or you used too much, so that there are too many suds in the washer. It can also mean that if you are using warm water, the hot water is not getting in. The hoses need to be checked to make sure they are hooked up on the right faucets and the hot water faucet should be turned all the way on. You would also need to unscrew the water hose at the washer end and make sure the little filter is clean, so tha the hot water can get through.
Good Luck!
Posted on Aug 02, 2008
Reset error code 90on an fridgidare affinity front load washing machine
Most front loaders have door latch problems, try to deactivate the latch.
Jul 12, 2015 | Frigidaire Washing Machines
My washing machine is running but there is a code EFO flashing on and off. (And, I can't find my manual...) What does that mean?
hello,
what this mean is an indication that there is flow of water in the (wiring system) sensing error above the normal level
what you need to do to fix up this problem is to open up the system and then clean up all forms of water of dirt around the wire and the screen and always keep note of the water level to avoid this again
thank you and thanks for using fixya.
Jun 11, 2010 | Frigidaire Affinity ATF7000E Front Load...
Affinity ATF7000E Front Load Washer: where do i find what efo means on my affinity wash...
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
May 16, 2010 | Frigidaire Affinity ATF7000E Front Load...
EFO error code
Jul 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
EFO displayed on my machine while running and beeped.
EFO is not a Kenmore Error Code.
Zanussi & AEG EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
May 15, 2009 | Kenmore 44102 Front Load Washer
EFO, E10 error Message
Feb 09, 2009 | Frigidaire GLTF2940E Front Load Washer
Fridgidare washing machine front loader
It can mean one of two things. You did not use an HE ( High energy detergent) or you used to much so there are too many suds in the washer. It can also mean that if you are using warm water, the hot water is not coming in, so you would need to make sure the hoses are connected correctly, the hot water is turned all the way on and that the little filter at the end of the hose (washer end) is clean.
Jul 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Flashing EFO error code
spoke with electrolux and they tell me that it is over sudsing problem. The washer must use HE detergent or use only a the lowest amount on the cup.
Jul 19, 2008 | Frigidaire GLTF2940ES Front Load Washer
Problems
Greetings tammym545,
Generally an EFO error on a front load machine is caused by using too much soap, or the wrong type of soap. Ensure you are using HE (High Efficiency) soap in your front loader. HE soaps are specially formulated front loading units to be low sudsing, which is essential to a front loader.
Thank you,
Agent Dort
Go Ahead. Use Us.
Apr 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
186 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
