Question about Frigidaire ATF6000ES Front Load Washer
Fridgidare washing machine front loader
I have an EFO error code flashing on my washing machine and and I can not seem to find out what it means. Has anyone else had this problem? Could you tell me what this means?
Thank you.
  • 876 Answers
It can mean one of two things. You did not use an HE ( High energy detergent) or you used to much so there are too many suds in the washer. It can also mean that if you are using warm water, the hot water is not coming in, so you would need to make sure the hoses are connected correctly, the hot water is turned all the way on and that the little filter at the end of the hose (washer end) is clean.
Posted on Aug 02, 2008
Reset error code 90on an fridgidare affinity front load washing machine
Most front loaders have door latch problems, try to deactivate the latch.
Jul 12, 2015 | Frigidaire Washing Machines
My Frigidaire Washing machine keeps flashing EFO in the ddisplay glass; What does that indicate?
EFO or EF0, indicates a problem with the detergent - either you're using too much, or you're not using HE detergent, which is meant for most front loaders.
Mar 26, 2011 | Frigidaire Washing Machines
EFO displayed on my machine while running and beeped.
EFO is not a Kenmore Error Code.
Zanussi & AEG EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2009 | Kenmore 44102 Front Load Washer
Fridgidare Front Load Washing Machine
It means one of two things. You either did not use an HE detergent or you used too much, so that there are too many suds in the washer. It can also mean that if you are using warm water, the hot water is not getting in. The hoses need to be checked to make sure they are hooked up on the right faucets and the hot water faucet should be turned all the way on. You would also need to unscrew the water hose at the washer end and make sure the little filter is clean, so tha the hot water can get through.
Good Luck!
Jul 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Flashing EFO error code
spoke with electrolux and they tell me that it is over sudsing problem. The washer must use HE detergent or use only a the lowest amount on the cup.
Jul 19, 2008 | Frigidaire GLTF2940ES Front Load Washer
Problems
Greetings tammym545,
Generally an EFO error on a front load machine is caused by using too much soap, or the wrong type of soap. Ensure you are using HE (High Efficiency) soap in your front loader. HE soaps are specially formulated front loading units to be low sudsing, which is essential to a front loader.
Thank you,
Agent Dort
Go Ahead. Use Us.
Apr 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I've read in a product review that Frigidaire put out a service bulletin regarding the electronic timer circuit board in these machines. Apparently enough of these boards failed to prompt a factory response. With this in mind, you should call an appliance repair center and ask them if they're aware of this Factory Service Bulletin. In many cases like this, where a part is manufactured defective, the repair could be free to you.
Aug 03, 2007 | Frigidaire GLTF1240A Front Load Washer
Error messages EFO and E10
It is simple. The wrong soap or too much soap will caused EFO to flash. I overfilled the machine with soap by accident. It started flashing with EFO and I went nuts. What could be wrong with it now?! Too much soap or not the right kind of soap will cause this problem.
Plus, I found a sheet of paper that gives the codes.
This is better than when the strainer plug gets filled up and you have to take the machine apart to clean the little strainer.
Apr 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
298 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
