Question about Kyocera Mita FS 3800 Laser Printer
We need local repair person
Need someone to come look at our copier. We are in Camarillo, west of LA I tried to remove the toner from my MITA DC 1455 copier and the toner tray bottom stuck while the top dislodged, spewing toner powder everywhere.
The copy color was too light even when I moved it to the darkest setting, so I don't know why there was toner powder in the tray and I don't know how to remove the bottom part of the toner tray and the fine toner powder without inhaling the toner particles. Please help.
Vicki Baldwin
I don't understand your website. I was charged 14.99 or so yesterday on my visa, but after your company accepted my payment, I learnedno one was available to help me. So I waited and this morning I have an email that is asking me to pay again or tell me how I fixed the problem.
It really is a simple problem that should be handled by you with a phone call rather than a lengthy internet procedure. I pulled out the toner tray and the bottom tray remained while the top came off and the powder spilled everywhere. I don't want to use a household vacuum on it. It is a mess. I need an approach to unhook the stuck bottom toner tray of the Mita DC 1455 (an old but serviceable copier) and replace the spilled toner with a new module. And how do I clean up spilled fine toner powder which is everywhere?
Posted on Jul 25, 2008
M559200308
It is not a colour copier and uses toner cartridge.
Aug 21, 2014 | Kyocera Mita Toner 37085011 for DC-3060 &...
I change the toner in kyocera FS-1135MFP but still it is asking to change the toner why ?
clean the developer and add toner powder to it then try to print without putting a toner if fine then install the toner problem solved
May 28, 2014 | Kyocera Mita Toner 37085011 for DC-3060 &...
System error cfb 30 kyocera 3060
CFB30 :
Incompatible Level Of Firmware on Main EEPROM.
May 02, 2013 | Kyocera Mita Toner 37085011 for DC-3060 &...
My copier mita dc 3060 showing error code c 210
Hello Manuel sorry for your machine to be in that stake but have you tried to check on that paper conveying motors because that error is for those lift motors try to go on your machine run this code
press status/job cancel
enter 1087*2 twice
enter 906 and then you will see execute
the you press start to see whether it will stablize
Sep 25, 2012 | Kyocera Mita Toner 37085011 for DC-3060 &...
We have a Kyocera KM4035 copier. Do any plastic strips need to be removed prior to placing the toner cartridge in the copier?
Kyocera toners usualy have red/orange coloured tabs which should be removed prior to fitting. The Kyocera Mita web sites often have instuctions on fitting, the Austalian site is particulary good for tthis type of info.
Aug 18, 2011 | Kyocera Mita KM-4035 Printer
Kyocera mita dc-1460 need parts
You might try to contact a Kyocera-Mita or Copystar Dealer in your area. But I don't think anyone will have those parts.
Jul 29, 2009 | Office Equipment & Supplies
Copies are very dark; almost grey
You need a service engineer to clean and service your copier.
Jan 18, 2009 | Office Equipment & Supplies
hi im jules_09,hi if you want i can guide you to repair it just tell me the problem then lets see,what went wrong
Nov 02, 2007 | Kyocera KM-1510 Copier
Mita DC-1205 Copier
Open the front door... on the right is your toner. It is a cartridge that inserts long-ways (front to rear) into the machine, and should be white or ivory in color. DO NOT remove the old toner cartridge without having a replacement on hand. The new cartridge will have a plastic "cover" on it that assists in releasing the toner cartridge locking tab, and "seal" the old cartridge as you remove it from the copier. The cartridge opening is face down upon installation into the machine, and you may get some spillage if you remove it without the cover. DO NOT remove the new cartridges mylar seal until AFTER you install it in the machine!!! There should be a picture label inside the front cover showing how to replace the cartridge. And there is a pictorial diagram on each new toner cartridge box also detailing this.
Use only MITA DC 1205/1255/1415/1435/1455 toner, OEM #MTA37041013. Should run you about $12-$14 per cartridge retail, or cheaper if shopping around (I sell them for $11.99). Do not use copystar brand for the same equipment. Although it's the same toner, the shape of the cartridge is slightly altered, and may not "fit" into the machine. I forget how it goes, either Copystar will work in Mita, and not the other way around, or vice-versa. Either way, better safe than sorry.
Oct 24, 2007 | Office Equipment & Supplies
Kyocera Mita FS 3800 Laser Printer Logo
69 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
