Back to:
Tags:
Lexmark X5150 All-In-One InkJet Printer
Dirty glass inside scanner
posted by stephenredin on Jul 24, 2008
have you found a way to clean the glass on the inside of your Lexmark 5150?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 30, 2008
FixYa! (100)
geokohler
Rank:Guru Guru
Rating: 88%, 148 votes
To clean the glass on the inside you must disassemble the unit so that you have access to the underside of the glass. If you save all your screws and are careful to lay things out in the order you remove the it is easy to put it back together and you do not have to worry about breaking anything.
Once you have access to the underside of the glass I use real windex and newspaper. With the newspaper you get a streak free shine with no lint particles. If there is dust inside the glass there is most likely dust on the scanners optics. Gently clean them the same way. Be gentle when cleaning the scan bar optics. They are not extremely delicate but it will break if you apply too much pressure as it is a long thin piece of glass.
When you put your scanner all back together it will scan as good as new and all the little black specs and streaks will be gone in your scans. I've done this 100+ times and it works every time. If you need help feel free to contact me an I will walk you through it for free.
I hope you found this info detailed enough to fix your scanner yourself, But If you need some help or moral support feel free to E-mail me and I will even call you for free. Make sure to say what you need in your E-mail as I fix a lot of things for people.
George
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on dirty glass inside scanner:
I don't want to Accept this solution
Can you Help with these Printers problems?
Our printer is stuck on energy mode.
Prints b lue lines on pink and also very red when copying...
Hi Phylli, I have same problem? :( Did you find the...
xd card stuck in printer
printer has error code saying not enough speed
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
