Question about Sharp AR-5316 Advanced Digital Imager Copier
HELP, H4 ERROR
I JUST BOUGHT MY SHARP AR-5316E, BUT IN LESS THAN 4 MONTHS IT IS DISPLAYING H4 ERROR. WHAT IS THE SOLUTION , PLS HELP.
  • Anonymous Aug 15, 2008
    i have the same h4 error but the solution given did not work for me
  • yusufcox Mar 04, 2009
    H4 Error cord
    President:
  • 2,072 Answers
H4 is normally caused by the fuser taking a little longer than normal to warm up. Most of the time it is not caused by the hear rod itself. I will send you the process here is a few minutes.
Posted on Jul 27, 2008
  • Rick Kasper Jul 27, 2008
    Give this a try. This clears that code 90 percent of the time.
    performing a Fault Reset 14 will reset your machine and will help to clear error codes.
    1. Find the pink Clear button on the Control Panel .
    2. Find the button below the word Auto.
    3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
      NOTE:
      All of the lights on the Control Panel should go out and the LED
      Display should go blank. If the lights do not go out, then repeat step
      3 until they do. It may be necessary to increase or decrease the pace
      of the [Clear], [Auto], [Clear], [Auto] sequence.
    4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
    5. Press the green [Start] button.
    6. Press the pink [Clear] button two times.
    7. The machine should now warm up and come to ready.
    8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
  • kingsley ejim Oct 04, 2013
    thanks
  • 24 Answers
This is a problem with the fuser, try a reset code first # * c* sim 14 start
Posted on Jul 26, 2008
2 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: HELP, H4 ERROR
The fuser isn't heating up on time. You could try turning the copier off for 30 seconds and turing it back on again to see if it goes away.
If it doesn't happen, there is a part that has to be fixed on the fuser to correct the problem. Usually it is the thermistor.
Posted on Aug 17, 2008
MY SHARP AR-5316E DISPLAYS H4 AND IS NOT WORKING
Dear friendscom, H4 :Heat roller abnormally low temperature.
__ possible cause __
  • Thermistor failure
  • Heater lamp failure
  • Thermostat failure
Perform the following procedure to reset the code:-
"#" key-- Interrupt key-- "C" key --Interrupt key--14--print
Jan 12, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
H4 error on SHARP AR-5316E plz help
h4 refers to the fixer/fuser, check to see if there is a paper jam in it
Jun 03, 2010 | Sharp AR-5316 Advanced Digital Imager...
My ar-5316e photocopier displays the number 2 followed by the letter H ... plz help
www.sharp-ro.ro/dyn_pdf/doc-AR-5316E-96.pdf
vinhco.com.vn/download/AR-5316SERVICE.pdf
http://www.eserviceinfo.com/index.php?what=search2&searchstring=AR-5316
service manual and user manuals above.
Jun 01, 2010 | Sharp AR-5316 Advanced Digital Imager...
My AR-5316E copier is displaying this error code H and 4
Your heater lamp maybe busted.
Use the simulation 14 to cancel the error..
If nothing happens then you need to check your heater lamp.
Oct 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
H4 error for sharp ar-5316e
Try reset the code by pressing [#] [Interupt] [C] [Interuptr] [14] [COPY/START]
If error still exist, check the thermofuse and the heater lamp
Jun 22, 2009 | Sharp AR-M205 Copier
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Is showing me H4 i need the solution now
Dear sir; H-4 Means heat unit problem, try to reset first,follow the steps as below;
1, press "#", " interupt", "clear", "interupt".
2, enter 14.press start.
3, power off and back on again.
If can not be reset then you have go to check the heater lamp, thermos fuse or thermister,
If you need more help let me know I'm alway here. Good luck, don't forget give me a good rating.
HAVE A HAPPY HOLIDAY !!!
Dec 21, 2008 | Sharp AR-5316 Advanced Digital Imager...
HELP, H4 ERROR
Aug 16, 2008 | Sharp AL 1215 Black and White Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
329 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
