Question about VillaWare Mini-Perk 5120-05 Coffee Maker
VillaWare mini-perk 5120-o5 clear perc top
I really would like to knowwhere I can find the clear plastic top to the mini-perk...The top split in half around the top and I need another top to peck...Thank you Yolanda
I have a miniperk 5120-05 that has stopped working.  I will let you have the whole thing if I can not get it fixed.
Posted on Mar 27, 2009
My new percolator will not perk? Water gets hot but doesnt seem to rise to the top.
I had the same problem, and I figured it out. Read on, to see if this applies to you. This percolator was received as a present years ago, and I'm not sure it ever worked right. First, some info and background. The above comments about the heating element being clean to bare metal, while valid, did not work for me. I also read other posts suggesting the thermostat might be defective, which also did not seem to apply to my situation because the water is always hot enough at the end of the cycle, not boiling, but steaming hot enough for just about anyone. I deduced the problem to be with the actual perking process, not heat or heating element. A percolator should perk before the water is at drinking (HOT) temperature, and the perking action cools the water and prolongs the actual perking process. The problem I found was with the washer at the bottom of the tube, which is supposed to act like a 1-way valve. The washer, from the factory, was apparently too loose with almost a 1/4-inch or play, allowing hot water that would otherwise perk back into the water chamber, effectively making my percolator into a kettle. I used a stainless steel washer and an e-clip to tighten the washer against the holes on the lower umbrella-shaped flange so that there is just enough room to slide a feeler gauge or perhaps a couple of sheets of paper. Now the percolator works great, fantastic actually. Watching the coffee perk at the top in anticipation of a hot cup is entertaining, and with the stainless steel pot I have no worries about phytoestrogens leaching from plastics common in drip coffeemakers. See photo of my hack if it uploaded correctly. Its high res, so you may be able to download and zoom in. Enjoy! new-percolator-will-not-n1see0xg4iab1sfdaqlesvfh-4-1.jpg
Oct 18, 2010 | VillaWare Mini-Perk 5120-05 Coffee Maker
Why does my FCP412 farberware coffeepot not keep the coffee hot?
<br /> KEEP WARM ELEMENT<br /> <br /> <font size="3"><font face="Times New Roman"><span style="mso-spacerun: yes"> </span>The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers. The KW element is $8.00 and $2.00 S/H. <a href="mailto:callahanronald@att.net">callahanronald@att.net</a></font></font><br /> Ron<br />
Aug 23, 2010 | Faberware FCP412 Coffee Maker
The first problem we noticed is the coffee is not as hot as it used to be, but it was still strong enough. Now the unit perks for about 10 min for a full pot, the light comes on....but the coffe is weak...
Hi, The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix. Thanks and please ask if you need more help. Ron For the part go to repairshack.com
Aug 17, 2010 | Faberware 10-22 Cup Coffee Urn
I have a 55 cup Farberware Urn. Pot will perc coffee sometimes & sometimes not. Problem exists since new, & have replaced both thermos. Water gets very hot, but not as Coffee. Sounds like...
Hi. The spring slips onto the stem just under the coffee basket, it holds the stem with pressure so the perked coffee go up the stem onto the spreader, check repairshack.com Ron
Aug 15, 2010 | Faberware 12-55 Cup Coffee Urn
My 25cup Farberware urn quit perking coffee can it be reasonbly repaired?
I have the same urn and had the same problem.
There are 3 common causes of lost perk that can be dealt with at home, and cause about 1/2 of the failures with these urns. They are very common when the pots are used rarely or carelessly cleaned after use, and when coffee is ground too fine for perc (drip grind is too fine for perc). As long as the pot is still heating, check these three things:
1) Clean the _inside_ of the hollow stem )that holds the basket and moves the water from the bottom of the pot to the top), to remove all grounds. You should be able to see clearly through it.
2) At the bottom of this stem there is a very small cup that has little holes in it and fits into the little well at the bottom of the pot. Make sure these are completely clear.
3) Scour out the little well so all residue/ grounds are removed and the little cup fits perfectly into the well.
It is the perfect fit of the two that allows the perc-ing cycle to occur.
If the pot is not heating, or these cleaning measures do not work, a local electric repair shop can probably do the repair for about 1/2 the cost of a new urn.
Dec 04, 2009 | Faberware 12-55 Cup Coffee Urn
Faberware FSU-122 coffee maker does not perk
Oct 16, 2009 | Faberware FSU122 Coffee Maker
Modelp r 134b 4cup faberware comes out like
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers Good luck. bobbyone
Oct 11, 2009 | Faberware Coffee Makers & Espresso...
Villaware 45 cup perc pot
Try to look under the machine, i think there are a reset pin.
Jul 16, 2008 | Coffee Makers & Espresso Machines
VillaWare Mini-Perk 5120-05 Coffee Maker Logo
194 people viewed this question
Top VillaWare Coffee Makers & Espresso Machines Experts
Tom Chichester
Are you a VillaWare Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
