On a pioneer elite plasma tv I cannot get the written text off the screen. I followed directions in book but when I go to "tuner" it is not highlighted so I cannot adjust display feature. I also have Comcast.
  • 13,433 Answers
What text are you trying to remove? also could you post me the model of your pioneer plasma.
Posted on Jul 24, 2008
Pioneer Elite plasma TV--top half of screen is green
What connection interface are you using. Can you try connecting another form of media and see the performance e.g connect to a computer or another TV box using another cable. If this persist, please visit a TV repair shop or call your manufacturer.
Jul 13, 2014 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Power Surge
charlie the proble has something to do with the tv guide here is a response from an older post Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was. Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Aug 05, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
Pioneer Elite Burn in; possibilty for repair?...
No,it is the Plasma screen panel itself must be replaced.Not possible,because by replacing the Plasma screen panel for the replacement,will cost the same as a new tv.So sorry no,u have to live with it.
Dec 06, 2010 | Pioneer PureVision Pro-1000HD 50 in....
My plasma does not split screan to show two channels (input) from the video recorder.
Correct. It doesnt. What are you trying to accomplish? If it is PIP from a cable box this needs to be within a dual tuner cable box. This has nothing to do with your TV.
Any TV that can do PIP has dual tuners.
Dec 01, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
Sep 24, 2009 | Pioneer Elite PRO-1540HD 60 in. Plasma...
My Pioneer plays DVD's and Blu-Ray but will not show the T.V.
Most likely its in the Media Reciever as the tuner is in there. If the set is showing a good picture on other inputs then that would be my guess. Pioneer has a flat rate to fix these and you may call their customer service to find out how much and where to send it 1800-421-1404 or plasma hotline 1800-421-1625
Mar 29, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
I can't get rid of closed captioning!
Closed captioning can come trough 4 sources 3 of them access a digital file and display it to the screen. ALL must be set to off on each device:
Embeded in actual program video source--unlikely your problem.
TV decoder cotrolled by TV menu under "language"
Cable box--ditto for menu selection
DVD player or VHS tuner--Ditto for menu
Sep 17, 2017 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Pioneer elite 504 pu 50 inch plasma black bar horizontal 2" thick in middle of screen
Pioneer plasma tv cut off while in use. Can't turn tv back on.
Aug 31, 2008 | Televison & Video
Could be heat build up in the Plasma display unit. Make sure it has the correct space around it for proper ventilation. Also count the number of blinks on the power indicator it is a code for the reason the unit shut down. On the Pioneer PDP-5060HD I have I was getting 12 blinks on the indicator which indicated a tuner issue. Check your instruction book for info on the over heating problem if it continues. You may have a fan out.
Apr 29, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
