Question about SanDisk Cruzer Micro 2GB USB 2.0 Flash Drive
I'm unable to find some important data stored in my Sandisk micro cruzer. I'm not sure if I accidently deleted it or if it is corrupted. Please suggest if there is a way to recover the files.
  • 1,719 Answers
If the pen drive is working, the data is there and can be recovered. I think it could be due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files and the space available for use is less than the capacity.
It is suggested that go to FOLDER OPTIONS - and select SHOW HIDDEN FILES. It may show the hidden files. Otherwise, you can use any data recovery program to recover the data. Please not that you should not sav/write any data to avoid overwriting the existing data.
Hope this helps!
CreativeTECH
Posted on Feb 14, 2011
SOURCE:
Dear Team Today when i try to use my CRUZER U3 (8GB) I GET MESSAGE "you have reached the maximum number of failed password...
Each U3 smart drive comes with a pre-defined number of login attempts. When you have only 3 attempts remaining, you will receive a warning message to prevent losing your data unnecessarily.
SanDisk does not have any method to bypass the password security feature on Cruzer U3 flash drives. SanDisk has not built in any back door or password reset methods. If the password feature is enabled and you exceed the number of incorrect password attempts, the drive will lock. Once the drive is locked there is no way to unlock the drive or gain access to the data stored on the device. You can only select the format feature, which will perform a secure erase (drive wipe) and data recovery will NOT be possible. U3 Cruzer flash drives which are password protected use 128bit AES encryption for data security
http://kb.sandisk.com/app/answers/detail/a_id/191
Sep 23, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
My SanDisk Cruzer Gator 4GB is not working. When
The filesystem appears to be corrupted. Try right-clicking the drive's icon, going to Properties, Tools and Check Disk. If that doesn't help the partition that holds the data may be unreadable, and if that happens try asking a data recovery service if the data is important.
Jul 12, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do I delete previously stored data from the cruzer micro
you can right click the file then delete or re-format the whole drive
Jun 27, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Deleted a folder containing files by mistake on my 4GB Sandisk Cr
Yes, one good way to recover deleted folders and files from Sandisk Cruzer is to use a Sandisk data recovery software. See this step by step guide
How to recover deleted files from SanDisk Cruzer
You may also try this guide
http://forum.001-software.com/pbb/viewtopic.php?f=4&t=13
hope this helps.
May 27, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk Cruzer Micro 4GB USB plugged it, light on, but shows an empty file in windows with capacity of 0bytes Also shows a CD drive (the one that U3 runs) which says nothing is in disk drive.
It is likely an issue with the filesystem. The FAT filesystem gets easily corrupted. If that's the case, reformatting it with FAT32 should help. But remember - reformatting erases all the data, so don't do it if you have anything important on the drive!
Oct 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk 4gb Cruzer Micro USB not recognized
If you want to add that to my ever growing pile of sandisk cruzers you are welcome.
Quality from sandisk has dropped considerably as can be seen from comments on their web site or doing a google search. It is very rare that I see other brands for data recovery. The cruzers have some software of their own on the drive that can get corrupted or deleted very easily. Once that happens you may as well toss it in the garbage.
Aug 10, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 8gb cruzer not working
Bring the Sandisk cruzer to any computer store that offers data recovery and back up or data retrieval. We called them the Data Recovery Center.
Most of them has a software they use in cracking passwords and other secured programs. From their computer, they could actually back up your important files saved in your Sandisk. Then you may now reformat your device.
Hope this helps and have a great day!
Jul 25, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
SanDisk 2GB Cruzer Micro USB I/O device error
I would recommend plugging your Cruzer into another computer. It's possible that your computer has corrupted or incorrect drivers for the flash drive. This is one cause of the yellow alert in Device Manager. If you move the flash drive to another machine and it works, you can save your data and make a backup copy. If your Cruzer doesn't work in a different computer (I would try at least 2 other working computers), it's possible that the flash drive is faulty.
May 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 2GB USB 2.0 Flash Drive Logo
411 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
