Question about Lexmark X5150 All-In-One InkJet Printer
Cleaning the inside of Lexmark 5150 scanners glass
Have you found a solution to this problelm?
  • 304 Answers
To clean the glass on the inside you must disassemble the unit so that you have access to the underside of the glass. If you save all your screws and are careful to lay things out in the order you remove them it is easy to put it back together and you do not have to worry about breaking anything.
Once you have access to the underside of the glass I use real windex and newspaper. With the newspaper you get a streak free shine with no lint particles. If there is dust inside the glass there is most likely dust on the scanners optics. Gently clean them the same way. Be gentle when cleaning the scan bar optics. They are not extremely delicate but it will break if you apply too much pressure as it is a long thin piece of glass.
When you put your scanner all back together it will scan as good as new and all the little black specs and streaks will be gone in your scans. I've done this 100+ times and it works every time. If you need help feel free to contact me an I will walk you through it for free.
I hope you found this info detailed enough to fix your scanner yourself, But If you need some help or moral support feel free to E-mail me and I will even call you for free. Make sure to say what you need in your E-mail as I fix a lot of things for people.
George
Posted on Jul 30, 2008
Use of Scanner
On this model there is a SCAN in black and white or color buttons but you need to have something on the glass to scan. Once it scans it prints!!!
Now lexmark software if installed comes with a program to scan with. you need to check under your prgrams folder under lexmark for the scanning software that was installed with the print driver.
If you open the lid and you do not see the white light chances are your scanner has and needs a bulb inside and at the point to install one of these you might want to concider a new printer.
Please be considerate and leave your feedback and comments and ratings before you leave, Thanks
Apr 30, 2010 | Lexmark X2500 All-In-One Printer
Getting a black strip in copy mode on X6575 lexmark printer. No line in print or test mode
Most likely a page was scanned with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | Lexmark X6100 Flatbed Scanner
Have Lexmark 5150 all in one, I load the paper and the paper pulls to one side and will not feed. I can't see any other paper stuck inside. ???
Following instruction from Lexmark tech support, I turned the printer upside down and shook it for 5 to 50 seconds. The debris inside fell out. Then using a damp lint free cloth I cleaned the rollers.
Oct 07, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark 5150 replacement glass: where to buy?
If you have a good glass shop in your area they should be able to make one.
DickyO
Apr 28, 2009 | Lexmark Wheelwriter 15 Series II...
Lexmark x215 MFP All in one - prints fine but photocopy and faxes
you should clean the optics situed in the upper place of the machine, retirate the originals glass en clean all the mirrors are inside...
good luck...
Feb 11, 2009 | Lexmark X215 MFP All-In-One Laser Printer
Lexmark x83 glass clean
  1. Dampen a clean lint-free cloth.
  2. Gently wipe the glass scanner bed.
These steps were taken from the Lexmark X83 User's Guide. You can find the English version here: http://www.lexmark.com/publications/pdfs/x83/engui.pdf
Sep 17, 2008 | Lexmark X83 All-In-One InkJet Printer
Dirty glass inside scanner
To clean the glass on the inside you must disassemble the unit so that you have access to the underside of the glass. If you save all your screws and are careful to lay things out in the order you remove the it is easy to put it back together and you do not have to worry about breaking anything.
George
Jul 24, 2008 | Lexmark X5150 All-In-One InkJet Printer
Clean inside of printer glass
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu01831&cc=ca&lc=en&dlc=en&product=79499
NOTE: The underneath side of the scanner glass cannot be cleaned on any product. This is unlikely to be necessary and should only be done by an authorized service provider.
This note is found on that website. For an authorized service provider near you: http://hp.infonow.net/bin/findNow?CLIENT_ID=HP_LOC_CAN_SRV (in Canada)
http://hp.infonow.net/bin/findNow?ONE=1&CLIENT_ID=HP_LOC_USA_SRV&PAGE=Search.html&LANGUAGE=USA_ENGLISH
(in USA)
May 23, 2008 | HP PSC 2210 All-In-One InkJet Printer
The inside of the scanner
you'll need a full service manual, of course...look under manuals service for lexmark online..
Apr 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
153 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
