Question about Canon NP 6050 Copier
E524 my copier says to turn off then on. It won't copy. We unplugged. did not help. thanks. dawn
  • 18 Answers
E524 is a problem with a motor in the sorter (M5 fails to operate). You can always undock the sorter from the copier after unplugging the sorter from the copier, and then just use the copier without it. You need to have the sorter serviced.
Posted on Aug 15, 2008
Loks to me like you have a problem... serious problem might be time to go buy a new machine. i know of the best place to get a fully functional machine. GUARANTEED (858) 292-4129 KCDS/BMU www.bmusd.com
Posted on Jul 24, 2008
Unplugged machine and now it won't turn on
Dear
Pl. check the power outlet of socket and power cable.
Thanks.
Feb 12, 2012 | Samsung SCX6320F Black and White Copier
We replaced the toner cartridge and the waste receptical and the little red light "Add Toner:" is still on and the machine won't copy. We have removed the cartridge and did the dance...
If it is a Kyocera toner than that is the problem. The key to turn the toner is different for the Kyocera toner cart. It will fit and appear to work but won't. Also turn the unit off and unplug for 15 sec. will reset and perform boot up procedures might help.
Jul 07, 2011 | Copystar CS-1810 Copier
I have a Toshiba estudio 202L copier. It has been working fine. When I turn it on, I hear it turning on like usual and see the light come on under the paper tray, there are no error messages, display...
try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Jun 14, 2011 | Toshiba e-Studio 202L Copier
I have a "Lexmark" X6150 Scanner/Copier/Printer.It list a an error as being "Cartridge error 50c" I put in new cartridge & it still won`t print a "Alingment Page" The Cartridge before didn`t last very...
Unplug the printer/copier from the main source of electricity, make sure it is a full ink cartridge, wait 10-20 seconds, plug it back in. Sometimes it takes unplugging it from the computer and doing the same.
Sep 21, 2010 | Lexmark Office Equipment & Supplies
WON"T PRINT
Hi Suzanne,
please answer these questions to understand issue better 1)Is it connected with usb or network
2)Are you able to make copies
Jan 21, 2009 | Office Equipment & Supplies
Np6545- erroe code e522
Hello Good Day amazingfirst! you problem for Canon NP-6545 error code E522 according to my Service Manual the problem is the Sorter push bar motor. try to check the sorter motor, add grease if needed so. just focus on the sorter motor ok! there is no need to reset the error code just on and off the machine and it will automatic reset the error code but make sure that the sorter motor will works ok!
Christopher
Jul 15, 2008 | Canon NP 6545 Copier
Sandisk sansa m250 not working properly
try upgrading the firmware as follows:
Before installing the player must be in MSC (Mass Storage Class) mode to run the firmware.All files will be deleted. Backup your files.
(To switch modes, Go to Menu > Settings > USB > The two options are MSC and AUTO DETECT (MTP) : select MSC)
Installation Instructions:
1. Download and run firmware from: http://www.sandisk.com/Retail/Default.aspx?CatID=1326
2. Follow instructions in installation.
Hope that helps!
Jun 20, 2008 | SanDisk Sansa m250 MP3 Player
What is service E524
This means the output value of the ADC sensor is below the required value.
Possible parts that caused the error:
  • Photoconductor Unit
  • SENSOR ASSY ADC
  • Toner Cartridge K
  • Toner Cartridge Y
  • Toner Cartridge M
  • Toner Cartridge C
  • HARNESS ASSY ADC
  • SENSOR HUM & TEMP
  • HARNESS ASSY MAIN
  • ROS ASSY
  • PWBA MCU
  • LV/HVPS
Head for the ADC Sensor assy first. It's the sensor assembly in the rear door below the fuser unit. Check that it is clean and clear of bits of paper etc.
try a replacement Photo Conductor Unit - even an old worn out one will do, just to see if the error clears. If it does you know your PCU needs replaced.
Much more than this and you will need an engineer to look at it as The High and Low voltage systems are not to be toyed with. Similarly the ROS unit if dead will mean the machine is beyond economical repair.
Oct 05, 2007 | Epson Aculaser C1100 Printer
Canon NP 6050 Copier Logo
124 people viewed this question
old marine
old marine
