NEED TO FIND A CONDENCER FAN MOTOR FOR A RHEEM 10 SEER LOCAL IN OR AROUND THONRTON, CO
  • 828 Answers
Call this number and they can steer you in the right direction.
(303) 892-1550
Posted on Jul 24, 2008
Rheem condenser fan motor
"the guy" added another start capacitor because the motor installed is actually better than spec. Your unit calls for 1/5 HP, 1050 RPM motor. The installed device is 25 rpm faster, and 1/4 HP.
The Rheem/Weather King/Corsaire/RUUD part number is 51-23055-11 (replaces many other Rheem/Corsaire/Weather King/RUUD Part #s including 51-21855-01)! It takes a 3 uf Capacitor rated at 370 volts. This Motor mouts with screws in the SIDE, instead of mounting studs coming out the back!!
Normal price for a generic motor w/ cap will be $125 or so, OEM part will be closer to 200. This is without the fan blade. Make sure you get the correct side mount studs.
This vintage unit is rated at only 10 SEER and is less energy efficient than a modern window air conditioner. Its days are numbered, and you are paying at least double every time it runs. Before you sink much money into this unit, please consider replacing it before it has a heart attack. Replacing it during the off season is cheaper anyway.
Please mark my answer down as helpful.
Jan 05, 2015 | Heating & Cooling
How do you clean the fan in a rheem air handler?
Pull the blower assembly...2 screws on the angle bracket holding the blower & disconnect the wiring if needed to the motor.
May 28, 2014 | Rheem Complete Split System Straight...
Rpnl-030jaz condenser fan not turning
if the fan does not run then it could be a bad motor or just the capacitor is bad. usually I check the capacitor first. it usually goes bad before the motor
Apr 14, 2014 | Rheem 2.5 Ton 13 Seer / Ruud Heat Pump...
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
I have a bryant 24-567c condenser. need replacement
you have a 3.5 ton unit.The evap will work with a new unit but it will not have the 13 seer performance that the new condencer with matching coil will give you.It is getting and harder to find the old 10 seer units check ebay and craigslist.
Aug 18, 2009 | Carrier 38CKC042 Air Conditioner
I have a goodman gmnte with a 16 seer ac, just
yes in the air handler the blower will have possibly 4 wires the ones you are needing are red blue and black1 will go to a relay or possibly a circuit board and the other 2 will capped off, black is high speed, blue is medium, red is low, most come from factory on med.
Aug 11, 2009 | Heating & Cooling
If installing a GSC140481 condensor with a ARUF486016 air handler is it necessary to change the txv to increase energy efficiency? Can these 2 units acheive a 14 SEER rating?
The real question is, am I going to get 14 seer using the old coil with the new condencer.If it is using r-22 then the old txv should work,but the old coil is proboby rated at 10 seer . since these were never tested together you would probobly see a minimal gain in efficency.Now if it is a matched set(ahri rated) you with definently get you 14 seer.Hope that helps!
Jul 09, 2009 | Goodman Heating & Cooling
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
