Question about Brother IntelliFAX 5750e Laser Fax
Poor line condition
Read your solution; however, what's a life counter? not in the user manual
My machine does not ring, so it does not answer the fax,what could be the problem? and can it be fixed
Posted on Aug 09, 2012
    Genius:
  • 2,120 Answers
It's the number of faxes your machine has printed and sent out.
Also you should have a Drum Life Counter.
Posted on Sep 30, 2008
OUT OF MEMORY
Hello laray7813,
Please visit this link to know exactky what NG means and how to solve it.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000009/faq000209_000.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=12
If this dosent work, let us know and we will find other solutions,
Dahaka
Jul 22, 2008 | Brother MultiFunction Center MFC-440CN...
Tip
Accurate Charging Methods of Central Air Conditioners
The charging (of an air conditioning system) alone can have a substantial impact on system operation costs. A few percentage points of over-or undercharge can raise electricity consumption significantly and shorten the life of the compressor." <span style="font-weight: bold;">You must invest in the proper tools, training and methodology to accurately charge an Air Conditioning system so that it works at maximum efficiency. Using the Thermocharge method to charge your air conditioning systems to the exact charge needed will save hundreds to thousands of dollars in electricity and maintenance costs over the years! </span><br /> Thermocharging method<span style="font-weight: bold;"> </span> <p style="font-weight: bold;">Skilled technicians will <b>"Thermocharge"</b> your air conditioning system with an exact refrigerant charge. This procedure produces an exact charge . . .not approximate, but exact. The Thermocharge method requires special equipment and training to use. Your installer uses the following instruments:<br /> <p style="font-weight: bold;"><br /> <ul> <li>1. An electronic thermometer</li> <li>2. Sling psychrometer or electronic humidity measuring device</li> <li>3. Refrigerant pressure gauges</li> <li>4. Accucharge slide rule calculator</li></ul> <p style="font-weight: bold;"> Here the tech is using the sling psychrometer to obtain the indoor humidity and indoor air temperature. He will double-check his figures with the electronic thermometer laying on the table. He will also verify the readings with an electronic psychrometer. <br /> <p style="font-weight: bold;"> After recording the indoor humidity and temperature the tech will go to the outside condensing unit to take additional readings. These are the following: <br /> <br /> <ul> <li>1. Outdoor temperature</li> <li>2. Indoor humidity</li> <li>3. Temperature difference, between air entering the evaporator coil, and the air leaving the evaporator coil</li> <li>4. Suction line temperature</li> <li>5. Suction line pressure</li> <li>6. Liquid line pressure (smaller copper line)</li></ul> <p style="font-weight: bold;">Enter this information into his special slide rule calculator to determine the exact amount of refrigerant to put into your air conditioner. <br /> <p style="font-weight: bold;">Let it run for about ten minutes to verify his figures. If there are any discrepancies, start the procedure all over again from the beginning. <br /> <p style="font-weight: bold;"> This Thermocharging method of charging an air conditioning system takes time and patience, but it guarantees that theair conditioning system will operate at peak efficiency all season long. <br /> How does accurate refrigerant charging help? <span style="font-weight: bold;"> </span> <ul> <li><b>Improved comfort</b> - A improperly charged air conditioner will not dehumidify properly.<br /><br /></li> <li><b>Lower maintenance costs </b> - A poorly charged system will not properly cool or lubricate the compressor . . .significantly shortening its life.<br /><br /></li> <li><b>Better cooling and efficiency</b> - Improper charging means that the air conditioner will not provide enough cooling on hot days, causing the system to run longer.<br /><br /> </li> <li><b>Improved efficiency and lower electric bills</b> - Poor heat transfer from improper charging results in increased power consumption. A 15% undercharge or overcharge can result in a 25% decrease in efficiency. This means that the homeowner's electric bill will be 25% higher than necessary. As the charge drops farther, efficiency decreases faster to 50% or more.<br /><br /></li> <li><b>Increased reliability</b> - A poorly charged system will not properly cool or lubricate the compressor . . . significantly shortening its life. Even if you have extended warranty by a heating company, you will either be greatly inconvenienced or even end up paying for the repair if the company stalls and you end up paying another company for the work . . .a $300-$700 repair that will void the warranty. </li></ul>
on Jun 05, 2011 | Heating & Cooling
Parts inside your printer are near the end of their service life. See your printer documentation. _ Epson R200 printer.
Regarding the Epson Artisan 800, I must thank FixYa and ask that the search for a solution be discontinued.Yesterday, I had an unfortunate accident while trying to unclog the print head which had been printing poorly over the last three months. I used a syringe to force a solvent solution through the clogged head. To my utter surprise the supply line exploded with a loud "POP" meanwhile spraying ink all over the place. At this point it was clear that it was pointless trying to redeem the old Artisan 800. Thank you FixYa. Henry.
Feb 27, 2011 | Epson Stylus Photo R200 InkJet Printer
I have this model printer (brother mfc-7840W) and i'm getting an error on the screen-it says Drum Error. See troubelshooting and maintenance chapter in the user manual
If you have the manual follow the steps for trouble shooting.
It will tell you to remove the drum, remove toner, clean corona wire and reinstall. If that does not solve the issue it will recomend replacing the drum. You can check your drum life by going to menu- press machine info, choose option 3 drum life and press ok. This will show you the remaining percentage of your drum if the number shows less than 25% replace the unit.
If it shows more than 50% you can reset the drum counter allowing the machine to read it as a new unit.( Bare in mind this will change the usage meter back to 100%, you will have to keep an eye out for print defects or light pages as this will signal the end of the drum life) to reset page counter remove the drum from the machine, with the front door open press Clear/back until the lcd displays reset drum yes? no? press 1 for yes and reinstall drum. The machine will cycle until ready; if this still has not cleared the message you will need to contact brother for a manual reset or service.
Jan 05, 2011 | Brother MFC 7840W Printer
What is Canon C3100 error code E000008 0001
The reading of the fixing roller life counter has reached its upper limit.just reach the counter reading at svc mode.
Mar 06, 2010 | Canon imageRunner C3100N Copier
Comm error 252
The comm error 252 occurs due to,
  • Telephone line conditions were too poor to receive a fax.
This error can be rectified by
  1. Reattempt the fax reception at a later time when line conditions may have improved.
  2. Configure the machine to start reception at a lower speed.
  3. If the local machine successfully received several pages of a larger document, ask the remote user to transmit the document in several smaller parts.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Jul 15, 2009 | HP LaserJet 3050 All-In-One Printer
How can I reset my Drum Life Counter on my Printer?
http://my.okidata.com/PP-B4250.nsf?opendatabase
Guide Users: B4250 download user manual
American English
May 06, 2009 | OKI B4250n Laser Printer
Error code A7 on brother mfc-420cn
Hi there
(A7 One-line feeding timeout error. )
Brother Error Codes RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 05, 2009 | Brother MFC 420CN All-In-One InkJet...
Bulb Life Timer/Counter Access?
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 29, 2017 | Hitachi 43UWX10B 43" Rear Projection...
Brother IntelliFAX 5750e Laser Fax Logo
67 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
