Question about D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater
DWL_ G710 unit. unable to access 192.168.0.30 in the URL box
Have tried many excercises, need units on line ASAP.
Thanks.
Victor.
IThe Dlink DWL -G710 t's a peice of ****. Throw the friggen thing out and get a real access point.
Posted on Nov 08, 2008
I bought the DWL G710 range exender hoping to boast range for ipad use, so can't use CD and tried the internet address given in the manual but it does not connect. Apart from the connection problem that...
Connect a LAN cable from the D-Link to your computer's LANport, open a browser and enter the D-Link's configuration URL. OR open thebrowser on your laptop and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now configure the wireless settings .
Feb 27, 2011 | D-Link AirPlus G Wireless Range Extender...
Got a DWL-G710 wireless extender that will not
First I would try a reset, as this extender should would with your default settings of your network.
I would suggest just giving your router a reset. Here are the procedures for your particular router:
Reset Procedure
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
make sure to setup your wireless security again and make sure to set an admin password on your router after the restart.
Oct 31, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
How to Change DWL-G710 IP address
in your case, you only need to change the range expander's IP address from 192.168.0.30 to 192.168.1.30
to do this, you need to connect a computer's LAN cable directly to the range expander's LAN port. when both devices are powered ON, then access the initial IP address http://192.168.0.30
when you are in the web interface, click the LAN button and enter the suggested ip under the IP text box: 192.168.1.30 see figure below.
when you already set the IP, click on APPLY. then you are good to go. You can then connect the router, then connect the range expander to one of the router's port, then computers.
Oct 22, 2009 | D-Link AirPlus G Wireless Range Extender...
DWL-G710 won't connect to 192.168.0.30
Here is a link to the manual for your DWL-G710.
D-Link manual on page 13 it lists the url entry should be
"http://192.168.0.30" This is a HTTP link not a HTTPS.
Also the address you typed in might be a typo. The IP address should be 192.168.0.30 not 192.168.0.30.
GOOD LUCK!!!!
Oct 18, 2009 | D-Link AirPlus G Wireless Range Extender...
Can't access the internet. No problem with the static IP address and setting up the DWL G710. Searched and found 2 AP's for my wireless account. Selected one and saved. Got indication that DWL G710 was...
Is there any particular reason you're using a static IP? Most routers are set up already for DHCP.
If you need to use a static IP, make sure you have the right settings for the default gateway and DNS servers (you'll have to contact your ISP to find out the addresses for the DNS servers).
I would recommend switching to DHCP though, and you won't have to worry about such settings.
Aug 02, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Cannot access the URL addres http://192.168.0.30 (page cannot be displayed) any suggestions?
check your IP address and see if the computer you are using is on the same subnet. your IP must be 192.168.0.xx where xx is any number. if you get a different IP address, use a static IP address between 192.168.0.31 to 192.168.0.40
how to check IP:
click Start - Control Panel - Network Connections - right click Local Area Connections - click Status - Details.
how to use static IP:
click Start - Control Panel - Network Connections - right click Local Area Connections - click Status - Properties - TCP/IP - choose Static - use any IP address in the range above.
click apply and try to access your repeater again. I am assuming that you have given the correct IP of your repeater.
Apr 17, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
DWL-G710 and DWL-700AP compatibily problem
when using the AP you have to make sure you set the SSID, channel & wireless key in the AP the exact same as the router and make sure when configuring the Ap that you set the default gateway as the IP address of the router.
Nov 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
DWL-G710
Move the repeater directly next to the router, connect to the repeater with a laptop/desktop and enter the configuration utility, see if you are even able to establish a "signal" status. If not, you may have a defective product or extreme amounts of emi.
May 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater Logo
1,117 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
