Question about Sony Cyber-shot DSC-W35 Digital Camera
Zoom strucked Sir, my cam fell down from my hand on floor, its zoom was strucked. what shall I do now. is there any solution for that.
  • 489 Answers
Hi
Your lens needs to be repaired or replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know, because I own one that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help!
You can also buy a defective camera online and use the parts to fix one from the two yourself.
Good luck from Darntoothysam com
Thomas
Posted on Oct 13, 2008
No zoom without battery without play pause
hi
If the battery is weak, must replace with a new one, zoom struck open the cam check the zoom motor on the camera section give a little lubrication to loos it, if the motor not working replace it.
Feb 21, 2016 | Sony Handycam CCD-TRV68 Camcorder
Zooming is not working probably while recording
Had this problem myself a while back.
NOTE - This is NOT a recommended procedure, and you try it purely at your own risk !!!!!
I knelt down and struck the base of the camera firmly but gently on a carpeted floor, then tried again. This worked for me - if you wish to try it go ahead. Good luck
Jul 29, 2017 | JVC Cybercam GR-DVP7 Mini DV Digital...
Zoom button stuck on full in zoom
Possible that the zoom switch is short or struck in action where by the zoom has gone to the extreme end. Wriggle the switch after the cam is switched off and see if it returns. If not the unit must be opened to check for the switch failure or possible motor failure, drive circuit or a mechanical jamming.
Nov 30, 2011 | Canon MVX200i Mini DV Digital Camcorder
Cam does not on and makes noise with company name displaying
The fault of a lens error be it in the shutter, zoom or auto focus is due to failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Aug 03, 2011 | Cameras
My camera dropped and the lens is stuck open. I can tell that it is not centered. The camera automatically shuts off.
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck/jammed while it fell down.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and realased. If none of these works then you can think of taking consensus with the service centre.
Jul 20, 2011 | Canon PowerShot SD1400 IS IXUS 130...
Dsc-2000 lens zoom turn in and out,whats the solution?
This lens error is due to failure of the ZOOM lens control system if the rest of the camera works well. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the Zoom drives, it must be free with manual movement. If jammed the motor can be removed and realased. If none of these works then you can think of taking consensus with the service centre.
Jul 14, 2011 | Sony Cyber-shot DSC-W30 Digital Camera
Instruction on zoom operation and also operation of flash on came
u have 3 problems here zoom,the flash and language ,ok to change the language hit menu .button then first word that shall be setup menu then word on the line number 3 and use right and left arrows to change ,the flash .turn the camera lens wheel on the pyramid sign u see on the front of the cam and then use the push button right side with zigzag sign to switch the flash mode ,push the button then up and down to zoom in and out
Mar 21, 2009 | Vivitar ViviCam 3750 Digital Camera
Problem with Memory card
hi sir
may be ur friend hade put the passward or sir just try to format it..
please sir format it..
Sep 02, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
My camera
Try resetting the camera. More than likely you are going to have to send it into repairs but try that first.
Aug 13, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Sony Cyber-shot  DSC-W35 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
