Question about Fuji FinePix A700 Digital Camera
Usb problem my camara says select pictbridges at usb mnode setting when printing when i turn it on, how do i get rid of that?
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey Ibanez_723,
I would try resetting the camera back to the default factory settings which is selected under the setup menu. I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
Go Ahead. Use Us.
Posted on Jul 24, 2008
I do not know how to set the time stamp for my FUJIFILM S1500. The date appears on the display screen when I view the pictures I have taken, but no longer appears once I download them to my computer??
The Fuji FinePix S1000FD camera supports time stamping only when printing pictures via USB with a printer that supports PictBridge. Otherwise, you will need to download the images and use an application such as "Visua Photo Time Stamp."
To print with PictBridge,
  1. Connect the camera to the printer and make sure the printer is on.
  2. Press the right-pointing arrow and hold for a second or until the USB logo is displayed on the camera
  3. Press the DISP/BACK button on the camera
  4. On the menu, select the PRINT WITH DATE option and press MENU/OK.
  5. Press MENU/OK again to start printing.
May 04, 2011 | Fuji FinePix S1000FD Digital Camera
How to stamp the date and time on the pictures? Fujifilm finepix J100
The camera will not deface your pictures by scrawling a set of digits across it. You can have the date appear when you print the pictures. Please refer to the documentation for whatever program you're using to print.
If you're printing from the camera using a PictBridge-compatible printer, you can set it to print the date by selecting PRINT ORDER (DPOF) from the Playback menu and then selecting "WITH DATE". It's detailed in the "Printing Pictures via USB" section of the manual (page 43 in my copy). If you need a manual, you can download one at
Mar 09, 2011 | Fuji Finepix J100 Digital Camera
How do I print pictures from my camera on the computer(pictbridge)?
The camera compares its PictBridge functions to the functions of the printer. The camera then displays the supported functions on menus on the LCD screen or in the viewfinder.
PictBridge print options
Once a PictBridge digital camera is connected to a compliant printer, print options appear on the camera LCD. The camera menu system is used to make settings such as print size, layout, media type and date.
You can print a single image displayed on the camera, print two or more images or print all images on the memory card. You can print part of an image by first cropping it within the camera and even create index prints, also known as contact sheets.
Print sizes and PictBridge
Not all PictBridge digital cameras let you select all available prints sizes, such as 13×19? if you have a wide format printer. If the printer has a memory card slot, use it and larger size prints should be available.
Is your device PictBridge compatible?
To find out if a camera or printer is PictBridge compatible, look for the PictBridge logo on the packaging or check the manual for specifications. If still unsure, call the manufacturer!
Jan 13, 2011 | Cameras
Can you tell me if this Lumix DMC TZ! camera comes with PicBridge feature? If so, where can I pull it up at on this camera?
Yes, the camera has PictBridge capability.
From the Setup menu select "USB". Make sure the camera is set to PictBridge instead of PC. For further details, please refer to the section "Printing the Pictures" in the manual. If you need a manual, you can download one from the manufacturer's web site at
Jun 11, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
Select picbridge at USB mode setting when printing (fujifilm camera A500)
You only use Pictbridge when printing directly from the camera to the printer. If you activate Pictbridge and connect the camera to the computer, you will get "communication error".
The printer also needs to be Pictbridge compatible.
May 08, 2010 | Fuji FinePix A600 Digital Camera
The device may be incompatible. Remove the device
Hi There,
Check the device connected to the Direct Print Port. Printing photos directly is possible with a PictBridge compliant device or the optional Bluetooth Unit BU-30.
A communication time out occurs if an operation takes too long or if it takes too much time to send data. This may cancel printing. In such cases, disconnect and reconnect the USB cable. When printing from a PictBridge compliant device, depending on the model or brand of your device, you may have to select a PictBridge compliant print mode on the device before connecting it to the machine. You may also have to turn on your device or select Play mode manually after connecting the device to the machine. Perform necessary operations before connecting your device referring to its instruction manual. If the error is still not resolved, check if you can print another photograph.
Mar 07, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Why wont my sony camera work with the polafiod pogo printer
You can print images by connecting the Camera to a PictBridge compliant Printer only.
Please make sure that your Printer is PictBridge compliant.
If your Printer is a PictBridge Compliant, select the USB Connect option in the Camera to PictBridge and then, connect the Camera to the Computer.
The USB Connect option will be located under the Setup2 menu of the Camera.
Dec 25, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
How to send photo from mobile to our computer
there are 3 ways
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
Jul 11, 2009 | Nokia 3110 Cellular Phone
EpsonStylus CX7450 and my prob is how to get the prenter to print straght frm my camaras memory card ? How do we see what picks are avalibe also? all info will be good .
the printer has a feature called PictBridge which enbles it to print straight from a digital camera, just make sure that the digital camera that you have is PictBridge compatible.
usually this PictBridge feature is a button on the digital camera that has an icon that looks like a printer with a paper in it. if you press that, you should have the option to view the pictures you want to print straight from the camera to the printer (please do note that this does not apply to all digital cameras you may want to consult your User's Manual for the said feature)
should you have other questions, just let me know.
Aug 04, 2008 | Office Equipment & Supplies
Fuji FinePix A700 Digital Camera Logo
49 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
